Can you tell me exactly how to do for posting a topic with one or two images?.. I’ve been trying to do this, but when I want to see it, the image is not displayed…
look in the faq in the help forum, tells you all about it, or you can click the ‘show forum code’ to the left of where you type in your post, and the tags are there, you can copy and paste them I think and just put your photo link between them. for the photo, make sure you right click on the page the photo is on and check the properties. copy the address in the properties window into there, ending in jpg,not the address in the explorer which often ends in html, not jpg. hope this helps.
also, you can check how its going to look before you post by clicking the preview button under the typing area. if your pic doesent show up, just keep hammering away at it until it does [:p]
Zeroenna, do you have your photos posted on the internet?
If not, you can try out www.photobucket.com or http://rongeorge.com/modules/Gallery/models
I am not familiar with photobucket.com but have used Ron’s site.
Login with the words below:
Username: newfsm
Password: models
Click on the upload picture and then where it says <> scroll down and hit the “add photos”
A pop up screen will appear and will browse your computer. Click on the pictures you want added and caption each picture with a short description. I think you are limited to 4 pictures of each model you want to display.
Once your photos are uploaded into Ron’s album, click on one to open it. Right click on it and click on properties.
Highlight the address ( example: http://rongeorge.com/albums/scifi/class1.jpg )and copy it.
Create a post on here and paste your image in between the brackets
[ img]…[/img ] ( except no spaces in the brackets … !)
It should look like this:
[ img]http://rongeorge.com/albums/scifi/class1.jpg[/img ]
I had to put spaces in the brackets so the lines above would print in this post. Once I remove them I get this:
Hope this helps some
Regards, Dan
Under the Community Assistance Forum there is a Sticky on How to Post Images. As noted, your images must be loaded on a host web site before you can post them on FSM.
Regards, Rick
