There wasa a question put forward as to How to select more than 1 image from Postimage and then post multiple pictures at a time.
I did a little exprimenting.
I was unable to select more than one picture at a time directly from Postimage for posting into an FSM reply.
This may be a mute point since I did a test trying to post(read: ADD) multiple pictures at the same time. I did this by copying three pictures to a file (Word Doc), then copying all the pictures in the doc and pasting into an FSM post.
It failed . Only one picture would post. I tried another method and only the last Picture posted. The last test only posted the 3 picture links.
1st test: 3 pictures “copied” and pasted into the Reply. Only one picture posts.
2nd test. The links for the 3 pictures were copied, seperated by commas and pasted into the Insert/edit field. Only the last link posted a picture.
3rd test:
Pasted the 3 picture links directly into the Reply field This results in just the links posting:
https://i.postimg.cc/pXv27tQ9/IMG-2008.jpg, https://i.postimg.cc/zG3X5MKN/Glencoe-viking-ship-w-horns-3.jpg, ttps://i.postimg.cc/YC0HtdLW/IMG-1090.jpg
It appears there is no easy way to post( ADD) multiple pictures at one time using insert/edit.
EDIT: Only one picture link can be added at a time but multiple pictures can be added to a Post by adding each one seperately before hitting Submit.
EDIT: Remember, you can still Copy a picture image and Paste directly into the Reply field, bypassing Insert/edit. I did the picture below using Copy and Paste instead of the Insert/edit Icon:
But there does not seem to be a way to post(correction:ADD) multiple pictures at one time unless you use an editing program that allows 2 or more pictures to be combined into 1 image file.
(See picture posts from Kirill4 as he has perfected the technique to edit/add 2 photos together and post as 1 image.
Edit: Another ticbit: You can copy an entire FSM Post and all the words & pictures in it can be pasted into a new post. That is how I created this thread. I made this entire “Post” in another thread and copied it and pasted it into this new Thread.
It looks like to add multiple pictures at one time I would need to find a program that simulates the FSM reply/post window. Creating such a file with pictures in it and then copying it to then paste into a Reply, would allow multiple pictures to be entered at one time. It means a member could work on a Reply/Post offline and then copy and paste the Post in its entirety, with pictures and words, into a new Post. All we need is an FSM Simulator.
If anyone has some alternative ideas, Please post’em.
Nino
