A long time ago, I acquired a Pocher 1/8 scale (art. KM/51) kit and placed it in the stash for a future project. Well, the future is here and I have decided to work on a project that has been lurking in the back of my mind for a long time.
Basicly, here is the project. Rebuild an old Monogram “Big Deuce” '32 Ford as a street rod and have it powered by the Ferrari V-12 engine. The '32 has been sitting on the shelf quietly falling apart over the years. Luckily, the old glue I used is easily coming apart and I didn’t paint the build back then so it’s practically falling apart. As I have been doing this on and off over the last couple of months while building 2 aircraft, it suddenly dawned on me that maybe the engine wouldn’t fit the frame. So, I started putting together the parts of the engine that I need to determine if it will indeed fit. Here starts the questions. In the Pocher box, there are lots of parts that are not needed for the engine. There are suspension parts, parts not shown on the instruction sheet, and other small parts that would be for a car build, like windshield wipers. Has anyone out there built this engine and run across the extra parts? Also, the plastic seems to be very soft and the rubber spark plug wires have some kind of sticky substance on them. Can this be just washed off or are they starting to break down and not usable? The instruction sheets are not very helpful as they do not show any suspension parts at all, just the engine itself.
In the process of dry fitting the parts I need to check for size, I have found that the parts don’t fit well at all. The instructions say that you need no glue or paint to build the kit. The main parts are held together with 3 small screws and the rest of the parts are force fit. From the few parts that I have dry fit, it is going to need a lot of filling and sanding and that means painting too. This isn’t a problem, as I expected to do a lot of filling and sanding during this project. Has anyone else run into these problems with the kit or did I just get a couple of bad kits?
I would like to do the project as a WIP, if you would like to see it. I’ve got tons of research on the engine but I will probably need a lot of help along the way and your input will be greatly appreciated.
Jim [cptn]
