Plugging the holes?
When you go to paint a model exterior in which you have not installed the glazing there are large holes which you do not want overspray getting into.
I would like to hear about some methods you guys use to temporarly fill those holes.
I tried using cotton balls but that was a disaster :frowning:
For things like pluging up landing gear bays and engine intakes/cowlings on airplanes, I like to wet down toilet paper or paper towles and shove the in the opening. When it is wet, you can get it to fit in just about any opening, and when it dries out, it is stiffens up. When you are done painting, it comes out pretty easy. Or you can put a couple drops of water to soften it up if it is stuck in tight.
I usually use wadded up toilet tissue.
I’ll often use foam pads used to apply makeup. A whole bag is very cheap, and they expand to fill holes quite easily - even large areas like landing gear bays.
Good one, Chuck. Water soaked toilet paper for me.
Silly Putty works well for the gear bays, and it’s reusable.
I usually use Kleenex, but if the opening is simple enough- say a rectangle, I will cut a piece of cardboard and fasten it in with blue tack, from the back. I can push it into interior and fish it out with tweezers.
I use expandable ear plugs if the holes to mask are small enough. Just mash em between your fingers and shove them into the space. Then they expand to conform to any shape. Eazy in,Eazy out. I also keep a pair handy when my SWMBO complains about how much I am spending on my hobby.
For open hatches on armor,I use cut up make-up sponges.For landing gear bays,I use dampened facial tissue,for cockpits,I use the canopy itself or stuff it with dampened facial tissue.
[:D[[t$t]
I use wet paper towels. They stay pretty strong even when wet and I can use an Xacto blade to really stuff them in the tightest of places.
Eric
Hi ;
I too use wadded up wet paper towels . It has always worked for me .
