Plege with Future
I cant find regular Future will the Plege with Future in it work?
Also can I just brush apply it to the areas where the decals will go and then rattle can on the dull coat?
Dale,
Same stuff.
You can do it that way but what you may get is areas that just dont look quite right since you have built up a clear layer under the decal and not the others.
Dale, future is now “Pledge with future shine” i believe, as thats what im using. and yes it brushes on real nice. is use a wide stiff brush and thin it with a little windex.
Nathan
I guess I will try to rattle can a gloss coat then.
Any brands you can recomend?
Thanks for such quick replys.
Good ole Testors Glosscote can work well.
What size brush do you use? 1/4?
It dosent run or leave brush strokes?
Future is self leveling
Yes, or wider if you have one, the future brushes on real even, especially if u thin it just a tad with windex, it doesn’t take much, as future is already pretty thin, you can actually see it start to run if you make a mistake and brush it on too thick or sloppy, but then it just blends in and covers real nice, much better than a rattle can would do. try it out on an old model or spare part first.
Nathan
Thanks for the tips.
