Looking for another fun project I came across this little gem.
(Sorry Bullion Express fans, it is still on hold). If it’s any consolation-- this project marries well in that Nemo is, its prime character as well).
Looking at the kit, the quality of its detail should produce a nice model. The kit comes with window masks and PE too! Nice…
I’ll start the project with what some call, the salon. It deserves some detailing because it is a neat section of the sub. Add some interior lighting and it should be to good effect.
Anyhow-- I must make it nice because I’ll be there many a night drawing plans for the Bullion Express. Also–Nemo likes to tip brandy and smokes cigars there. That’s when he is not sinking ships for sport. Maybe if he is in a good mood, he will share brandy and cigars with me. Big maybe! [:(]
Because of time limitations I expect this project to span months and progress could be slow. Updates could be mundane for that reason. Just giving a heads up on that. But-- that is part of the journey for me.
Thanks for the link, John! It is a good read, and there are some good tips there.
The reviewers point about detailing the interior is a common complaint with this kit. Poor lighting is a major issue. Some builders complain that even with adequate interior lighting the jeweled window assembly finishes off the problem by distorting what a person can see. You can see shapes and such, but that is about it.
I am firmly in the camp that if I can’t see it, I don’t waste time on it. But, and that is big but, I hope to CHEAT! Lighting is a must, and I will do that, but I will make the window assembly removeable. Then if a person wants to see the interior in all of its glory, you can. That is the plan, anyway. Lol.
I recall seeing and commenting to Bobs salon. It looks awesome! I hope we see more!
I haven’t seen the kit itself till this post. Now I am wondering, can .010 sheet be cut for those salon Windows? I might try a mockup first. It might not be easy, But, might improve the clarity thereof
I’m building this kit now. Will will be lit with a Voodoo kit. Right now, I’m pondering what finish the exterior will get. I’ve looked at lots of builds and examples online.
Hey Dave, thanks for chiming in. What finish are your leaning towards? Like you, I have been looking at other builds. I am leaning towards a rust brown. How far along are you on your build?
I didn’t think I’d be posting today but here is something to chew on. I removed and cleaned up parts for the salon. Until I did this I didn’t know just how much detail they put into this. I like it. Below are a series of images showing how this assembly will look. Keep in mind these are loosely fitted and “kind of” being held together by tape.
I thought you guys would like to see this. The images are best viewed by clicking on or expanding them.
Below: See the door at the far right corner? I may be opening that up. I had seen someone do that and then light it from behind with what was probably a flickering tealight. It gave the effect of an engine room and it was to good effect.
TB-- here is pic of the windows. On closer inspection the clarity is not too bad. I think the bigger issue is the facets, angles, and ironwork. Replacing all those panes would be a massive and precarious task. I will stick with my plan to make it removeable.
A screencap taken from the Disney movie and it shows the color they used. Of course, that said, it is up to the builder. Pegasus designed their own version of Nautilus, and that opens the door even more to creative license.
Man that is nice detail and the clarity of the far window even shows Cptn. Nemo’s wine storage—Oh, wait. I get it now, that’s Your paint bottles–Geesh I was sure fooled there for a moment
Seriously, looks like a great model and will be a pleasure to watch your progress.
I may have seen that thread, I just don’t remember it.
I watched a resin build on YouTube and that kit is 31 inches long. The model is much more in line to the Disney version. He followed the same rusty appearance. I do like that look, and since there is a basis for it being that way-- I am 98% certain that is how I will go with it too. I watched some clips from the movie and some sections of the interior have mild rust streaking too. That said though… I would not think bad of anyone doing it different. It would be cool to see this boat in copper–or corroded copper, or brass even.
For anyone interested, here is a link to the 31 inch build I had watched. I like this channel. The guy does good work and I appreciate his sense of humor too!
I’ve worked on the lighting electronics and begun painting the salon interior. I’m still undecided about the exterior color. (One of my other hobbies has captured my OCD attention, Ham Radio.) I’m sort of torn between a rust finish, maybe:
I like steel and jet exhaust. I used one of the metal colors on the civillian build of the Hannebau.
Maybe I’ll try to use both rust and metal colors. There are a few online builds with nice rust finishes. I have the hull painted with Vallejo black primer.
I don’t know if you are aware, but Greg is into Ham Radio as well. You two should talk. If I can help facilitate, let me know.
I was looking at the M&M treatments as well. I watched two videos where the builders tried it on their Nautilus builds. The oxidation effects are amazing, though, extreme. The good news is that it is easy to brush off and get the look that you want. You have probably seen those videos. Both builders were less than happy with the outcome, but both admit the error was on their part. In one case the problem boils down to his base colors and his preshading. The other was a case of applying more than one application.
I am on the fence as to whether I will try it.
I like your choice in models. I have looked at those UFO kits as well. Nice job on those!
