I finally tracked one of these down in the US at an anime convention and she cut me a sweet deal on it…because I knew what it was!!
http://www.entertainmentearth.com/prodinfo.asp?number=DC98755
Kotobukiya has done a fine job with this kit in 1/72 scale of on unusual subject. In Patlabor 2 the Hannibals that were sent to Veit Nam on peackeeping duties didnt fare well at all. The heat and humidity got to them, the daily grind of muddy operations, and the quick final ambush did them in as seen in this AMV
http://www.youtube.com/watch?v=XGe4ByCkDnk
To the kit:
good assembly overall, I didnt have any issues with it. anyone famliar with Bandai’s instruction format will pick this up quickly. Interior is far given there isnt much to see anyway. 1/72 scale Japanese mech drivers are in short supply so I am still working on that. Prepainted with spruce green ( Zaku Green as I call it) and then overpainted with white gloss. I worked through the white paint in high wear corners to reveal the green underneath. Given thier short life span they saw enogh action to accumulate some wear. Pencil was used judiciously on the extreme corners.
I think most people avoid the white version due to the monochromatic look. I got some great adivse to use neutral grey for the shading on white vehciles, and used Reaper Minatures Rainy Grey with a glaze medium. this almost acted as a filter and took the starkness off the white paint, layed in depth and as tan was added twoards the bottom a level of dirt. Flesh Wash from Citadel was used for the hydrailic staining. most of that will be covered so you will only see a bit of it, not like what you see here. MIG Pigments are next once it all goes togethether, I painted the flexible joints today and those are drying so they are not in the pics.
Optics and the viewports will recieve further work. The lights and lenes are getting dark purple lenses like the IR lenses fitted to 80s US army helicopters for NVG use. I just realized the stop lights on the back of the backpack havent been painted yet. I;ll fix that later. Handrails and such still need to be added. The blue lenes of the viewports add some much needed color, but the only real color comes from the smoke grenade launchers on the sides of the hull, which are ringed by a colored band indicating color or starshell. Markings are dry trasnfers from Woodland Scenics, Archer Fine Transfers and WAVE Options parts. My cat gave up a whisker so that will go to the antenna behind the big IR illuminator on the hull left side.
!(http://i20.photobucket.com/albums/b244/ThePlasticFanatic/Scale Modeling Album/hannibalparts.jpg)
!(http://i20.photobucket.com/albums/b244/ThePlasticFanatic/Scale Modeling Album/upperhull1.jpg)
!(http://i20.photobucket.com/albums/b244/ThePlasticFanatic/Scale Modeling Album/upperhull2.jpg)
!(http://i20.photobucket.com/albums/b244/ThePlasticFanatic/Scale Modeling Album/upperhull3.jpg)
