Passionate Poncho II
My next build waiting for paint to dry on my other stuff . Looking though my stash I found another Pontiac a 62 Catalina pro stock? trying not to build it stock[whstl] may take a while
This is a great kit. To do it stock, you will need a extra set of thin tires and front wheels if you can get them, or sand down the rears to the proper thickness.
started on the engine and painted drilled holes for spark plug wiring
Perfect color. FYI, paint the transmission behind the bell housing steel.
ok I’ll use metalizer since its gloss blue any way
If that blue is enamel, the Metalizer will wrinkle it. Best bet is testors steel brush paint.
I must of been lucky I’ve always use gloss black enamel for base coat then metalizer don’t jinx me[:D]
here is an up date on the engine all box stock except for distributer and wiring
Looks good, just one suggestion, spark plug wiring doesn’t rise up from the distributor in a fountain shape, each wire flows down alongside and then usually along the valve covers to each plug. Other than that, she looks good.
Kinda looks like a dady long legs dont it
ok hows this
body is washed and primed with mm enamel.ready for testors artic blue metalic
my 1st two mist coats of testors artic blue metalic now some drying time
The base coat done more drying time. Next the wet coats now I work on interior
Engine looks much better. Nice color on the body.
Great job on the motor! What shade of blue did you use? I’m building 1986 El Camino and I’m trying to figure out what shade of blue to paint the motor.
Thankyou midnightprowler and rocker. its the 1/4oz testors GI light blue 1108 code.
working on dash board and steering wheel got gauges form best model car parts
Wow!
