Looking to build an F4U for my dad for fathers day. He’s always been interested in Boyington and his ‘Black Sheep’, so I’m looking to build him a Corsair for fathers day…just one hitch, I can not find any decals for Boyington. Anyone know whether or not the Tamiya kits supply these decals?
There are plenty of Boyington decals around. Most are for his “photo op” F4U that he never flew, 86/Lulubelle. Superscale, Aeromaster, and I am sure many others have this one on several sheets. I think it was Cutting Edge or another company that did several F4Us he was known to have flown. Just check your favorite online hobby shop search for 1/48 F4U decals and go from there.
Cutting Edge has a Black Sheep set but I can’t find it anywhere for sale. You can see the sheet in a number of reviews and with enough googling you could probably find this set for sale. Here is the link to the reviews, http://modelingmadness.com/others/decals/leece48226.htm
There is also a resin figure of Papy for sale too. That might be nice for a dio for your dad.
What kit are you going to build?
I’m going to build the Tamiya F4U-1D I think. I’ve looked everywhere for Boyington decals, (not lulubelle) and I can’t find anything at all…thinking about paying someone on here to make a set for me if I can’t find any. I’d pay a good price for a set.
I used dry transfer numbers to model #883, the F4U-1A that he was photographed in shortly before he was shot down. You can find these in the model railroad section of most hobby shops, as well as online. There are several sizes on each sheet, so you can use them in many scales. I’m still using the sheet that I bought appx 12 years ago!
Ditto, what he said…
The famous “Lucybelle/Lulubelle” Corsair was actually a Corsair that was based on at New Caladonia… Like Stik said, it never got any combat hours on its clock. The kill markings were hurriedly applied (that’s why some are upside down). as was the name and Boyington’s stencil… It was just for a publicity shot…
The name is still argued about, but “Lucybelle” seems to be the actual name… Pappy was involved with a gal named “Lucy” in Seattle once upon a time…
From “The Black Sheep”, by Bruce Gamble ( A “must read” for Pappy fans and VMF 214 model freaks, BTW)
Bruce Matheson later remarked on the informalities.
Boyington in “883”…
!(http://img.photobucket.com/albums/v233/HansvonHammer/Aircraft Profiles/F4U Corsairs/pappycorsair883.jpg)
It was said that he was quite hung-over when this photo was taken… [t$t]
!(http://img.photobucket.com/albums/v233/HansvonHammer/Aircraft Profiles/F4U Corsairs/Boyingtonin883.jpg)
VMF 214’s aircraft were heavily weathered… The ground crews didn’t concern themselves with washing or repainting planes at all… If there was battle-damage that didn’t hit anything vital, sometimes a scrap piece of aluminum sheet, removed from wrecked aircraft, was just pop-riveted into place, and a little paint slapped on it… That is, if it was one the fabric… If it was fabric, sometimes “100 mile an hour” tape was used…
As you can see, there isn’t much in the way of decals needed… Just the National Insignias, and some dry-transfer numbers…
Another “wrong” F4U for Pappy…
This one’s in the US NAval Museum at Pensecola… They shoulda known better…
!(http://img.photobucket.com/albums/v233/HansvonHammer/Aircraft Profiles/F4U Corsairs/BoyingtonF4UNavalMuseum.jpg)
Keep in mind, Boyington flew F4U-1s (birdcage variant) and F4U-1As, but not the F4U-1D… I believe you can convert the Tamiya -D kit to a -1A though. Don’t use the belly pylons, use the different canopy on the kit sprue, paint over the window on the belly and fill in the step on the wing. I’m not sure if there were other differences.
Edit: found this link that may help:
Looks like most everything is already covered. Make sure that you do not use the rocket stubs or whatever they are called on the F4U-1A. Do use them for a -1D. Also, check the references for the presence or absence of the mast on the right side of the forward fuselage. And if you are going for accuracy you will need to remove the small air scoop near that mast location as it is not on the -1A or -1D.
I am also building a Tamiya F4U-1A into a -1D. Fortunately the parts are in both kits to do either one.
Good Luck!
I am actually going to use a 1A instead of the 1D kit… I still can not find the decals for pappys 740 or 883, but I plan on using my wifes cricket to cut out stencils and paint the numbers on. As far as I know neither a/c had any type of markings other than a/c number on the fuselage. If I am wrong in this thought, someone please provide me with a photo! I’m desperate.
Can’t tell you all how much i appreciate your thoughts on this build!!!
Sorry, I could not find a definitive photo, but it does appear that F4UI-1A aircraft had two bits of small black data on the tail. On Navy corsairs, painted in small black letters and numbers on the vertical tail, about half way up is the word “NAVY” and below that is the Serial Number (or is it the Bureau No.?) of the aircraft. On the rudder in the same font and color at approximately the same height is either “F4U-1A”, “F4U-1” or the S/N repeated. I have seen photos that show all. On F4U-1D aircraft I have seen photos that show “F4U1D” on the rudder. The decal sheet I have for the Marine Corps 86 “Lulubell” (SuperScale 48-38) has the word “Marines” above and “18086” (the serial number) below on the front tail, and F4U-1 on the rudder. This aircraft was an F4U-1A though. Most likely a SuperScale/MicroScale error.
So personally, lacking photo evidence I would just use what is on the decal sheet if you can find it. If not I would put this at these locations (assuming aircraft 883):
Front tail (center justified):
MARINES### 17883
and on the rudder:
F4U-1A
Here is a link where you can see the size and locations:
http://acepilots.com/images/lulubelle3.jpg
More info here:
http://acepilots.com/usmc_boyington3.html
The artwork looks just like the photos, the printing is too small to make out. This might work in your favor though
Hope this helps more than hurts.
Good Luck.
