Panel Lines
I need advice on how to raise panel lines on aircraft.
Do you mean “raise panel lines” or “create panel lines”
If you mean raising panel lines; I have never heard of that being done.
But frequently modelers will create panel lines with a panel line engraving/etching tool.
N.
use streached spruce. heat it then pull then use an acrilyc cement to glue it on. superglue and regular glue will melt it. enjoy
i mean create panel lines
DSFM 29:
The best way to create panel lines is to scribe new ones. This will create the much preferred, recessed panel lines.
The Tamiya panel line engraving tool is excellent. I bought a less expensive brand once and it worked O.K. Then I got the one from Tamiya and it is excellent for engraving lines.
The other needed tool for creating new panel lines is a flexible steel ruler to guide your tool on an aircraft’s curves.
I’ve got a line scribing article on my website if you’d care to check it out. Go to the “How To…” page.
My technique is a bit off the beaten path, but it works!
www.spasticforplastic.1hwy.com
My apologies in advance for all the pop-ups!
Fade to Black…
