paints-mixing
if you mix semi gloss blk with 10% white & flat base, you get flat blk dont you??
I would think you’d get a flatter very dark grey. You can always apply a clear flat over the black if that’s the effect you’re looking for.
I agree…apply black and then flat coat it. The semi gloss will go flat pretty easy.
Andy
What you get will depend on the paints you are mixing. Different brands of the same color, even as basic as black and white, have different pigment loads. What you would get from this mix is probably a shade of dark gray. The luster would depend on how much flat base you added—could be anything from dead flat to eggshell, or even satin, depending on the binder and additives in the semigloss. For some glossy paints, killing the shine of the cured coating with a flatting agent is almost impossible.
As others have suggested, if you have a semigloss black, and want it flat, overcoat it with a clear flat. Not only is it more efficient, it’s much easier!
