Painting steel and other metallics by brush.
Hi, I don’t have an airbrush (and don’t know how to use it in any case), so all of my paints come from a can or delivered via brush.
I’m having trouble applying metallic paints (acrylics) to my models without them looking streaked and fake.
Any hints? Thanks!
This is for 1:48 scale kits.
I always found that I need to put a primer down first and then use a wide enough brush loaded with paint which should lay a nice covering coat on the first swipe. To little paint on the brush will cause streaks.
I use a medium/dark gray primer in a spray can, then dry brush Testors aluminum (a flat aluminum) to give a weathered steel look. There is a tremendous variety of appearances to steel, depending on alloy, and time of weathering. Polished steel, especially stainless alloys, are next to impossible to brush properly, but weathered steel of many alloys can be done by various techniques, the above only being one.
The spray can type paints metalizers or Tamilya synthetic lacquers are out there In metalic form.
Yeah, I use them from the can when I can. [:)]
Unfortunately, sometimes it comes down to places that are too small to be sprayed. Appreciate everybody’s help, though!
