Painting question RE: Tamiya F4U-1A Corsair
I just purchased my first Tamiya model and picked up the recommened paints on the side of the box. While looking at the directions I’m noticing a lot of numbers with these paints. Please tell me I don’t have to mix these paints together. For example, XF-3 : 2 + XF-5 : 1. Does this really mean that I have to take two parts XF3 and one part XF5 and mix them together? This will be my first model that I airbrush and would hate to think of how much time I would have to put into something I’m just starting out in. Any thoughts? Do I mix or am I reading this wrong? I’m using all acrylics and was recommend that I put down a base coat of the Testors Acryl white primer. Is it ok to mix brands?
Thanks,
Burt
Burt,
I am afraid so. Tamiya’s paint range is rather limited in some colors, so rather than come out with additional colors or worse yet recommend a competitior’s brand, they have you custom mix the colors you need. IIRC, the color callout that they are referring to in your example is US interior green. Tamiya doesn’t make a color close to this, but Polly Scale (another brand of acrylics) does. Their part number for it is #F505096. HTH! [tup]
Thanks for that bit of information. This will be a great lesson I’m sure. I hear so much great stuff about the quality of this paint, but yes their colors are limiting. I’ll do my best on this one and possibly switch brands that have a better range on the next one.
So should I just prime all my pieces at once while it’s still attached together? Do I need to thin the primer like I would the paints or does the primer just go straight on without thining?
Thanks,
Burt
