So i decided on another paint scheme for my 1:48 F-14D. Whats the best way to strip paint off? Ive got a black nosecone that i want gone! Anyone out there… heelllp!
Well, what type pf paint did you use? Enamel or acrylics?
DOT3 Brake fluid removes enamels
Windex or, rubbing alcohol removes acrylics.
hth,
Eddie
hmm its enamel… i dont happen to have brake fluid… anything around the house that you can think of… ive tried bleach… not so much luck…
Got any nail polish remover? The kind with Acetone in it. If not, use some paint thinner & elbow grease.
Some people try easy off oven spray but, I haven’t tried that yet.
Easy Off oven cleaner will do the trick, outside of course. Simple Green also will work but takes a little longer on enamels(non-toxic too).
