Paint removal.....
Hi all !!!
I’m painting a Fiat body, and i don’t like the way it’s coming out. Is there a way i can removeall the paint and startover??? Without harming the plastic??? the paint is getting kind of thick, and is strting to distort some of the body features… the paint i used is Colors by Byd, in a spay can…
Thanks for any help you can send my way…
Ron, try soaking it in Simple Green overnight. If that doesn’t work break out the Easy Off oven cleaner. Be sure to use gloves and ventilation.
if i use oven cleaner, do i saok it, or just spay it and let it sit for a few minutes…
thanks for your help…
This link will tell you everything you need to know. [:D]
http://www.bonediggers.com/1-3/strip/strip.html
Thanks, that site is pretty cool… i’ll have to go buy some castrol tomorrow…
littlemoe-
Funny you ask this question as I finished stripping the paint of my Revel Jordan EJ10 body yesterday. I had started painting the body about a year and half ago with ‘plasti-kote’ primer and House of Kolor’s yellow but didn’t finish the job. I recently decided to start over and searched this fine BBS and found the link that MikeV has referenced.
Off to Wal-Mart I went on Tues. and purchased the Castrol Super Clean in a purple jug for $5.xx. Today the body is a clean canvas to work with.
Now it did take about eight hours or so for all the paint to come off but I am overly pleased with the results. What I did was take a tupperware type container, filled it with the CSC and dropped in the body. Every few hours I checked the progress and slowly but surely the paint just disolved right off with no scrubbing. Pretty cool.
HRD
The funny thing is, i used to use that stuff all the time when i built engines for a living(1:1 engines).that stuff was great!!!
Thanks for the advice everyone!!!
HRD,
Are you using adequate ventilation with those House of Color urethanes? Better be real careful as they are isocyanates and can enter the body not only through the nose but also the eyes.
Does that explain the pink elephants … LOL LOL
I build a spray both with an exhaust fan and all that…
Thanks for the concern though…
That’s good Ron, but you said you were using Boyd paint and not urethane toners. [;)]
yes, colors by Boyd, in the small spray cans… The booth is ok right???
I’m sure it’s fine. My point was that there is a big difference in enamels and urethanes as far as toxicity go.
Thanks Bud… I do 2 small boys, 5 and 3, so that is always a concern…
Pink elephants…I’m way beyond that now…
MikeV - thanks for the concern. Ventilation is always a concern but in this case not a problem :slight_smile:
WOW…!!!
This Castrol Super clean works great!!!
Best gosh darn 6 bucks i ever spent
I use CSC too. The only thing I’ve seen it stumble on is the Tamiya Spray lacquers (or whatever they are…). I used brake fluid on that (also quite nasty stuff that needs to be used with caution) and it seemed to work.
Murray
I need to try that CSC sometime to see what the rave is all about. All I have ever used is Easy-Off oven cleaner in the yellow can which works great, but it sounds like the Castrol is even better. [8D]
