Okay, I need some help here guys. I’ve just encountered a slight problem, I painted my 1/72 scale P-47 Thunderbolt from Revell with Testors Enamels. So far, I’ve gotten an undercoat of aluminum. Now, I planned on using it as a base coat for weathering effects. but after some looking into it, I like the polished metal look! I went to paint the first of two or three coats of testors sky/light blue and discovered the paint was way to thick! (Yes, I am crazy, I’m hand brushing a model in almost all enamels!) I tried to thin it out but it had little effect, and the damage was done. I stripped the paint w/ thinner and a tissue and now I have to lay down a new layer of aluminum because it was destroyed by the stripping![:(!]AAAAHHHHH how can I keep this from happening. BUT MORE IMPORTANTLY, does anyone know of any cool paint schemes for P-47’s. I loved the portfolio section on Brian James in the Jan. 04 FSM issue and was drawn to his unique 1/48 P-47 bubbletop. That’s the look I want, except more original! So, any ideas???
Stephen, you might try the various aftermarket decal manufacturers websites, such as Aeromaster, Cutting Edge, Sky Decals, etc. They post the profiles of the aircraft depicted in their decal sheets, many in color. Also, check out many of the online hobby shops and distributors, such as Squadron, ScaleHobby and GreatModels. They carry many of these lines of decals and will also have the profiles on their websites. You can also find plenty of markings in publications, such as the Osprey series of books on the P-47 and the various Squadron/Signal publications. There a a great many references out there if you know where to look. I wish you luck with your search. Hope this helps. - Ed [8D]
When painting with a brush, it is very difficult to get coverage over the aluminum. The metallic paint (especially MM chrome silver) takes a l o n g time to dry. To prevent this in the future, paint the metallic only where it will go. If you want to show the aluminum underneath by “chipping” the top color, put a coat of Future over the metallic. You can apply some metallic paint to a scrap kit, or the inside of a wing, let it dry for a few days, then try brushing some paint over it. If the same thing happens, wait a couple more days & try again. Eventually, you’ll know how long it needs to dry.
Hope this helps.
Thanks for the tip, but I gave it a good 72 hours to dry and the real problem was with the blue, and I did consider the future coat, but I didn’t want it to look “buffed” so I opted not to do that!!!
