PACIFIC CARRIER AVIATION GROUP BUILD
Alright fine, here ya go, the corsair:
and the hellcat cockpit
I finished masking the canopies on the Trumpeter Dauntlesses. It’s kind of fussy work, but not too hard. I used thin strips of ordinary low tap masking tape, and positioned it around the canopies’ base, then I used MicroMask to fill in.
Next step is painting the interior color–which can be visible through the canopy even in this small scale.
Nice paintwork on the interior of your SBD, Johan!
Good looking Corsair, Josiah!
Checkmate
I am impressed at the level of attention you give to such micro-scale planes. I have a hard enough time at my age with 1/48 scale.
Josiah: Looking very good!
Checkmate: I saw you building those Wilcats already, but your great work in that tiny scale keeps impressing me every time. Major kudos to you!
Josiah: Thank You for the pics. Everything is looking excellent. Curious, is your Hellcat Mk.II a Profipack kit in that comes with PE and canopy masks? Also, what brand of paint are you using for the chromate green in your Hellcat cockpit?
Checkmate: Very impressive indeed. I have to say that it is really fun watching you paint up the 1/700 aircraft. Someday I’ll get my feet wet building a ship model. I’ve got a few in my stash including USS Hornet and Ticonderoga so your techniques on the aircraft are being duly noted.
I’m currently getting everything test fitted on my Hellcat. I must say that this here little Ediuard kit is Sweet! They did a fabulous thing on this kit in the way that the wings and tail planes mount affords you the ability to paint them separately and install them afterwards. Nice. Although, I have encountered an issue with the tail plane mounting tabs. They are slightly too long and when they meet inside the fuselage the planes stick out too far. Thus, some sanding surgery will be required. Clemens and Josiah, I’m not sure if this translates over to the 1/48 scales. You might want to check that out. I’ll get some pics up of the test fitting right soon.
Thanks Rob, Clemens, and Joe! I appreciate your comments.
At my age, too, if I didn’t have reading glasses and a 10X Optivisor, I’d never be able to do anything with these 1/700 types!
I applied interior green from Testors MM to both sides of the SBD’s. Since the pieces are molded in clear plastic, some things aren’t easy to see until the paint goes on–like the huge divots/sinkholes on the bottom. I’m not going to do anything about them, since these particular planes will end up on the hanger deck. And anyway, sitting on their landing gear should conceal the flaw.
When the green dries, I’ll apply the light gray undersurface color.
Thanks guys…checkmate, holy crap those are small, I don’t think i’d be able to do that even with all those magnifying thingys!
Joe…it’s the weekend edition, so not extras and only one marking for a plane. I’m ok with that though, can’t really afford all the extras and I’ve never done PE or resin. The plastic is quite detailed anyways. Thanks for the head’s up too.
I can honestly say I feel the parietal and occipital lobes of my brain seizing as I try to come to grips with how I would venture into such tiny scales. =P
I definitely have more patience to learn.
Sounds good Josiah. Eduards weekend edition kits are indeed very nice OOB. Should you ever consider venturing into the PE/Resin realm the Eduard Profipack kits are a bargain when you consider cost with what extra is included.
Here is a pic of the test fit of major components. The cowling comes in 2 halves and are thusly glued together and the front intake PE grill is installed. I have almost finished sanding down the tail plane mounting tabs to where I am able to fully close the fuselage halves. I regret that I forgot to take some before pics of this issue. I’l try and get some of the completed effort.
Looking good, mate!
How exactly is the cowl split up on the 72nd kit? The 48th one is split into 2 halves and the cowl ring (with some fit issues).
I built one of the profipacks some time ago, but I wasn’t happy with the results at all, so It went into the trash before the painting stage. I jsut felt like I didn’t do the kit justice, but I learned some important lessons while building it. Then I picked up the royal class at Hannants (it was 1/3rd off too) and those 2 Hellcats should be very enjoyable builds for me.
Clemens, the cowling is split on the top and bottom. It’s important to note that you need to maintain the seam on the top as that is a panel joint. The bottom seam on the other hand needs to be smoothed out.
Well I finally have some progress to report. I’ve managed to finish most of the cockpit and install it into the airframe. The PE version of the instrument panel is too large for the cockpit and so it was a bear to jam in. However I managed to coerce it in without destroying anything. I was also able to start working on the engine. I still want to add the PE for the wiring harness. Any advice on wether it is easier to paint it first then install it or paint it after? My concern is the paint flaking off the PE as I bend it to fit the engine.
And now the obligitory pics…
Looking good guys…Joe I forgot to tell you I’m using Model Master Acrylic for the green zinc chromate…dunno if it’s right or not but I didn’t feel like buying another bottle and I’ve seen numerous british hellcats in the zinc chromate…though I guess that’s like using wikipedia as a source in an essay :wink:
Looks like I missed quite a bit when I was skimming through between classes and work…thanks for the heads up on the assembly Joe.
Got some progress ish on the corsair…my airbrush is being all wickety wack and I dunno how the finished paint job is going to look on the corsair.
I brush painted some blue on so when I put on the airbrush coat it’ll have a kind of shading effect…we’ll see if that actually works though ha.
Josiah and bvallot: the little planes are not nearly the trouble I’m having with the PE railings that go on the ship itself. I don’t know why I do it!?
How’s the Corsair coming, Josiah?
Rob H: very nice-looking cockpit. I admire your work with the PE.
For a small update, here are my SBD’s with WEM’s US Navy Light Gray on the bottom.
It appears Trumpeter had some molding issues with the bottom of the plane, as I mentioned before–huge sinkholes under the cockpit and some gnarly little issues around the wing edges. They show up even better under a coat of light gray paint!
While I mask and paint the upper surfaces, I’ll also paint the little tire/wheels with an acrylic black and a brush.
Looking good checkmate…corsair is stalled…had midterms and a bunch of papers due this past week…I planned on doing a bunch of painting done this week (spring break) but alas…just got about 8 inches dumped on us.
Where are you living, Josiah!? We’ve had snow and lots of it–but not 8 inches in one sitting!!!
Maybe it is caused by the “seasonality” of winter, but my building is slower, too.
Anyhow, I’ve got the upper surfaces of the SBD’s painted. First, I used strips of masking tape to cover the lower wings and stabilizers, then used ticky-tack on the fuselage bottom.
I stuck the whole thing onto a bottle cap to make handling easier, and proceeded to paint.
When everything was dry, I applied a black acrylic pin wash to the panel lines, and painted the front of the engine cowling black to represent the engine.
Next up will be decaling. This will take a couple of days to finish, and I probably won’t get back to it till Thursday or Friday.
Still looking good checkmate.
I’m in virginia…I love snow, especially during hunting season and when I can get classes cancelled. It is not hunting season, and my college has a really early spring break, so I’m just SOL hahaha. They were calling 8-10 and I took a ruler and it was an average of 8…I drove down the road a mile though and it only looked like 4-5 inches…maybe when it was windy all the snow blew off the trees? I dunno, VA weather is weird though…last week it was in close to 70 for a couple days LMAO
Josiah:
Virginia is a good looking state–very scenic, although I haven’t been there since the '80’s. Visited the Civil War battlefields as far as Petersburg, and been through the Shenandoah Valley a couple of times, and to Virginia Beach…
Never ran into any snow, though!
Here in Wisconsin, we’ve had a total accumulation of 64.1 inches since winter started; records broken for cold weather (as low as -30’s with windchill), and not much relief in sight.
I’d like a couple of days in the 70’s right about now.
