Finescalers
which way does opening in paint needle go when reassembling?
does opening go up toward air venturi or down for paint
to drop and then be drawn back up?
Thanks
Finescalers
Thanks
It doesn’t matter which way the opening faces. It works the same either way.
How do you like the EZ Starter?
Don
Don
Going to use it first time soon, let you know then.
What’s the spare bottle for?
I do think a Badger 250 looks simpler and more trouble free, are they?
Thanks
I don’t have an EZ starter, but it’s pretty much a clone of the Badger 350. The 250 is for sure simpler, but a 350 and your EZ starter should be just as trouble free. The 250 lacks a needle and doesn’t spray as fine, although it’s good enough for many purposes.
I don’t know what the spare bottle is for if the spout cap doesn’t fit it. That was the case with my Harbor Freight 350 clone.
A brief review of your EZ and maybe a photo or two of the parts would be interesting.
Don
Don
thanks for the badger 250 info!
will be using it for simple painting models
did figure out spare bottles are for mixing
Is badger 250 easier to clean after using?
What do you mean it has no needle?
will post pic’s asap
Thanks!
Have a look at my review of the 250 and the one on my 350 and you will see the difference. They are both very easy to clean.
If this is your first airbrush, practice on some junk plastic before you paint a model.
Don
Don
Read the reviews.
Didn’t see a review of the Testor’s Mighty Mini set.
Did see some remarks about low air pressure and
avoiding all-in-one compressors.
What PSI do you think the Mighty Mini puts out?
Does low air pressure cause clogging?
Thanks
I can’t find any specs on that compressor, but it looks like a glorified aquarium pump. You might want to read the reviews on Amazon. If you don’t have enough air, the paint will spatter. To me, anything less than 1/6 hp is marginal.
Don
Don
What do you think of Testor’s acrylic paint?
I want to avoid clogging this time around.
Should I move up to Model Master paint or
it is it a thinning problem?
How much do I thin the Testors acrylic?
Thanks
Sorry, I can’t help you much with paint. Maybe some of the guys here who are more knowledgeable about it will chime in. You might have to start a new thread with that question.
Don
Don
Okay, will start a new thread on that.
Meanwhile, have a few airbrush questions left.
Plan is to have a clog free painting session.
Does more air pressure mean less clogging?
Looks like my Testors Mighty Mini only puts out 15psi.
Thanks!
I think you are going to need a bigger compressor. External mix airbrushes like your EZ starter do best with 25 to 35psi. And, that’s operating psi, not static. Volume is as important as pressure. But, it may surprise me. Try it and let us know how it goes.
Clogging depends a lot on paint and thinning.
Don
Don
Thanks!
What do you think of a Hobbico Badger 250 knock off?
Hobbico might be the Hobbylinc house brand.
Is the Badger 250 the least clogging leader?
Is the opening it has pretty sturdy for cleaning?
Thanks again!
I think you are making the same mistake many beginners make of trying to go too cheap. In the long run, you will end up wasting money. Get a real Badger 350 or Paasche H and you will have something reliable with good performance. Get a real compressor with a regulator and moisture trap. A lot of modelers are happy with this one. Then, if you have clogging problems, it’s due to the paint. If you are in this hobby very long, you will spend much more on kits and supplies than a decent airbrush setup will cost.
Don
Don
I already have that compressor bookmarked on Harbor Freight.
Keeping it in reserve.[:)]
Now that you pointed it out that pulls things together
that it’s equivalent to the Paasche and Badger as far as features.
I didn’t think alot about the air gauge and moisture trap before.
Thanks
