I’m looking for a new air compressor. I only have a big one that delivers 30-180 psi (a little much maybe). My LHS has a Paashe D500 w. R75 Regulator for $140.00.
This is a Paasche D500 Compressor w/R75 Regulator. This 1/8HP Compressor is economical and suitable for all airbrushes spraying properly thinned fluids. It is capable of delivering 20 - 40 P.S.I. operating pressure depending on airbrush being used. The Paasche D500SR is an oil-less piston unit and comes with the R-75 Regulator/Filter with gauge.
It operates on 110-120 Volt, 1 phase, 60Hz, and delivers .4 C.F.M. @ 20 P.S.I. R75 Regulator will regulate up to 40 P.S.I. depending on usage (intermittent or constant) and size of airbrush being used.
I actually have a 1.5 gallon compressor that goes up to 180 PSI that I could probably work with. The only problem is that I can’t get any replacement parts for it as the manufacturer went out of business. Not a big deal but my wife thoughtlessly broke off the air filter when I left the compressor out in the middle of the floor and she was carrying my laundry to the machine. If I could replace the piece she broke I could use this one.
Other than that, Canadian Tire has a 2 gallon one that goes to 125 psi that goes on sale for $50.00 from time to time.
I use a reasonably quiet Paasche DA400 for airbrushing in the basement workbench.
I keep my Sears 1-HP oil lubricated tools compresssor in the garage and bring it inside only when repair/remodeling work requires it. The Sears compressor is a bit less noisy than most low cost oilless compressors, but I still found it too intrusive in enclosed quarters.
Quick Update - I finally got my filter assembly back on using MacGyver-like ingenuity. Once that was done, I took everything apart and re-teflon-taped it. She doesn’t leak anymore.
Now I have to build a spray booth so I can actually try this airbrushing-thing out. [:O]
