Hi all,
after receiving samples of MR Models new Upgrades/Conversions for Tamiya’s 1/48 scale M4 Sherman, I decided to do a quick overview on the sets.
First is a set of stamped spoked roadwheels and idler wheels for the Sherman. The bag has fourteen roadwheels and two idler wheels cast in grey-green resin. Casting itself is good with crisp detail and only a small casting block on each wheel allowing for easy removal. For the size of the parts (1/48 scale ) the detail is excellent. The roadwheels have well defined details including the grease plugs, relief valves and the twelve small retaining rivets (!) around the rim. The two stamped idler wheels are perfectly cast also featuring all the small details and have nicely done hubs. The axles holes are drilled out making the wheels ready for use.
As an option to # MR-4805 this sets only gives you the mantlet parts for the early M34 mantlet instead of a whole new turret. It comes with a replacement inner mantlet for the turret with both styles of narrow M34 mantlets ( plain early type or later version with barrel protection extensions ), the barrel shield for the coaxial MG, two resin MG barrels, separate pistol port, metal barrel, trunnion + bearing and breech block for the 75 mm M3 gun. The casting of the parts is good with some care necessary while removing the mantlet parts from the casting blocks. The inner mantlet is cast with the lift rings and nice screw head details, but has no casting number. The fit of the whole gun assembly is very good with the metal barrel perfectly sitting in the resin parts (mounted through the outer mantlet into the inner gun assembly). If carefully installed the gun will be fully moveable. Sadly, the barrel is lacking the flared muzzle.
Last is a replacement set containing two drive sprocket wheels and four idler wheels for the Sherman. You get the two stamped idler wheels from set # MR-4806 as well as two welded idler wheels. Casting of the parts is good with nicely reproduced details (see above). The drive sprocket wheels are cast in two parts each with beautiful bolts on both sides of the drive sprocket wheels. After some minor cleanup they are ready for use. Again some care should be taken while removing them from their casting blocks.
A full review should be available on PMMS site in the future as I send out samples to Terry.
HTH
Frank
