Is there any advantage to using the Tamiya Thinner? The price is about 4x…more if you buy at Costco.
Thanks!
Thanks!
Tamiya thinner contains an acrylic retarder. If you use 90+% isopropyl alcohol, you have to add your own.
Ross,
Does it matter if one is already retarded?[:P]
Gip
No, but it helps!
Only if they call you “Snake-eye”… [:-,]
im using water is that retarded?
Water retards the drying, that’s for sure…
I use straight 91% to thin mine. It works great IMO, but it does dry fast. For cleaning brushes, 91% is awesome.
So I guess it doesn’t matter if you don’t add too much then.
Thanks!
Thanks!
Adding too much retarder can cause serious problems with your paint. Up to a certain amount, retarders slow the drying and curing of the paint. Beyond that amount and they do one of two things:
I have to use 91% alcohol here in Florida. The humidity doesn’t allow for fast drying unless you do. I have found it works well and helps keep the spray in thin even coats. Plus the cost is way cheaper.
I use either 70% or 91% alcohol for cleaning brushes and the air brush. But stick with the brand thinner (Tamiya …ect). When thinning the paint to air brush.
My 2 cents…
I’ll second that. I use the Tamiya thinner to thin the paint and I use 91% isoprophyl alcohol to clean the airbrush.
I’ll third that!
Although, I sometimes use straight 91% for certain paint effects. [tup]
