Hi all,
Here’s a smaller project from Córdoba, Argentina: Academy’s 1/72 OV-10D Bronco. It has just won a Gold medal in the “Propeller aircraft, 1/72 and smaller” category at the IPMS Argentina Nationals in Ensenada!
The kit: Academy’s OV-10D “Desert Storm”, the upgraded Bronco from the NOGS programme, with the extended nose and FLIR turret, IR-suppressed exhausts, extra pylons and the long-range centreline tank. It’s a reboxing of their OV-10A with an extra sprue for the D-specific parts. Typical early-2000s Academy: raised panel lines, a basic interior and decent fit, with a little filler here and there. Tip: the long nose has room for nose weight. There’s space for 8 g, but I’d recommend 10 g to avoid a tail-sitter.
The scheme: instead of the box’s Desert Storm options, I went for dark olive green and grey, closer to the earlier operational Broncos. It shows off the shapes better and lets the modulation work stand out.
Construction: the cockpit is very visible, so I painted it carefully, added the pilots and scratch-built the ejection seat handles. The booms were the trickiest part, glued progressively to avoid any twist, and the upper wing was dry-fitted over the pod and booms to check the geometry before gluing it at key points.
Canopy surgery: I separated the canopy into sections like the real aircraft: marked the lines, cut it with a razor saw, then sanded and polished the edges to bring back the clarity.
Rivets, black base and modulation: before priming I went over the wings, fuselage and booms with a rivet wheel guided by tape, so the rivet lines show subtly through the paint. Then black primer, panel-by-panel modulation using the black as the shadow, and the base colours in thin coats. Camouflage demarcations were masked with tape and putty for soft edges.
Decals, weathering and varnish: kit decals over a coat of Blem acrylic floor wax, settled with setting solution. A dark wash removed in the direction of the airflow, dirt on the gear doors, exhausts and maintenance areas, dry pigments and a few controlled chips. Satin varnish to finish.
The best moment was unmasking the cockpit and seeing the separated canopy sections and the interior clean and visible after all those stages.
Comments and critique are very welcome!
Cheers from Córdoba, Argentina,
Ale (IPMS Córdoba)
