Okay, I’ve surfed various forums, have some books but is there one book/source that goes from absolute start to finish. I think I have some idea on how to mix, but where to mix, how to mix, ratios etc I struggle with. Any ideas would be very gratefully used!
That’s always a tough one as every company has a different mix ratio.
Model master puts a book out celled modeler’s technical guide full of info. But its mostly about there products. Most paints today are part of a system so its always safe to use the thinners that are made by the same company as the paint.
Allways mix a little as possible and go up from there and put down thin coats.
My way is anything but scientific, no real formula or fixed ratios, but it works for me. Here goes.
The expression “thinned to the consistency of 2% milk” seems reasonable to me, but what does that look like exactly? I’ve poured some in a glass jar, dipped the stirring stick in and placed a drop on the inside of the jar. That gave me the consistency of the milk drop as it slid down the side of the jar, but I’ll be darned if it seems the same to me with thinned paint.
I think what works for me is to thin to less than the consistency of 2% milk, in some cases with Tamiya acrylic I have made it ridiculously thin, maybe as much as 1:3, paint to thinner. Might sound weird, but it really went on well.
For enamel I begin with a 3:2 paint to thinner ratio, but almost always have to make adjustments as I go through the test spraying process, before actually beginning the project spraying work. For me it was a lengthy learn as I went process, but what I do now seems intuitive and pretty much easy.
I’d suggest maybe buying a batch of paint, start playing with thinning ratios and just spray away. I imagine we all have variations from normally recommended formulas, but I consider them only base line suggestions, likely we end up just doing what works well for us.
You might check out the publications available here at FSM, I think Aaron and others have written plenty of guides for painting.
Absolute start to finish? Don’t know of any resource that will help you with that. But it isn’t as hard as it seems and many of us have our own way of mixing paints for our airbrush. First - where to mix? Wherever you darn well please. Me, I mix in little medicine dosage cups but some mix in their airbrush bottle/cup but use what you have. How to mix? Put a little paint in the container add some thinner and stir with toothpick, straw whatever. Ratios? Whatever works for you and your airbrush and depends on nozzle/needle size. For example I can spray Testors Acryl straight from the bottle with my Iwata Revolution (0.5 mm nozzle) but have to thin it alot when I use my H&S Evolution (0.2mm nozzle). Too, I don’t know how thin 2% milk is but it’s quite runny [is that a word?] so paint for my airbrush has to be quite ‘runny’ too. I think an important issue when starting to airbrush is trying to get ‘complete’ coverage with a single coat - a first light coat may appear that you haven’t applied much paint but the third coat really looks great and that means your paint/thinner ratio was right for you and your airbrush. Sorry I don’t have a start to finish refernce for you but my advice is to get some paint, thinner and ‘play’ til you get what YOU want.
