Jeff,
It was my pleasure to help out the best I could.
If you want one of the Iwatas later on then that is fine by me, I won’t hold it against you. [;)]
Jeff,
It don’t mean nothin’ It will just make appreciate the Omni more[:p]
Needle lube?
Would that make spraying mottle camo in 1/72 easier?
I was doing some last week, and the trigger appeared to stick a little, making control just that biy more difficult to control the paint flow.
Karl
Hey mike, in your pic of all your brushed is the 4000 in there so I know what it looks like.
It would probably help. I put it on the needle itself as well as the link on the tube that holds the needle and rides against the trigger. It makes things a lot smoother.
I’m not Mike, but the Omni 4000 is the one on the top right in his picture.
Which one is the top feeder on the right, third one down?
I can’t tell … have to wait for Mike.
That is a Thayer & Chandler Vega 1000.
The airbrushes are as follows:
Left, top to bottom:
Sotar 2020-2
Badger 100LG
Badger 360
Badger Anthem 155
Badger 150
Right, top to bottom:
Omni 4000
Omni 3000 (Scooter Shooter) Customized version of the Omni 3000
Thayer & Chandler Vega 2000
Iwata Eclipse HP-CS
They all have quick connects also so I can use any one at any time with just one hose. [tup]
Pretty cool, Mike. I didn’t even notice that you had a 3000.
I can use one hose with all my airbrushes to! I just have to unscrew it each time [:P]
i dont need hoses! they are connected to my azteks
