Here we go again![zzz]
Hi George,
So, for the most part, I think the “correct shade” debate is rather pointless. If one cares to model a pristine factory fresh Shermie or “whatever”, the "correct shade " thing may have some merit. However, most of the crew on this board that delve into allied WWII stuff like to throw a little dirt,dust,muck,slime and what have you over that OD.
Not to mention, I feel, to make the model visually interesting and not appear “toylike” at 1/35th scale and smaller, the base coat must be lightened and / or darkened in certain areas to imply realism. The basic rule is, paint the model as if it were in natural light…i.e., in the areas on the top, lighter, in areas that would be more shadowed (sides) a little darker and so on. This is the key to making OD look interesting and real. Throw on some pastels or pigments and presto!
Here’s a few examples of what I mean…who cares what “shade” the original base coat was on these builds? Weathering and filtering make "shade of OD " a moot point IMHO:
I start with spraying the entire tank flat black or a very dark gray:
Then mist in the base (In this case IJA Green!), leaving the preshaded seams, panels and what have you, to show thru:
Then go back over with lighter shades (filters) in a vertical streaking motion, and highlighting the top of the hull and turret:
Finally on to the detail weathering, stains, dust dirt etc…
And badda-boom badda - bing:
You already have conflicting opinions as to your subject in this thread, and believe me, it has been discussed and debated before on this board MANY TIMES.
My advice…don’t worry about it. Just get close, and apply weathering with the various techniques that myself and others swear by, and you will put out a great build.
Good luck
Steve
