I recently asked a question in regards to the purpose of muzzle brakes on cannons. The responses were all so informative that I thought I would ask another.
Does anyone know the purpose of a Notek light system on German vehicles? I thought they were used for convoy travel, but am not sure.
EJH
They are the same as modern day black-out drive lights on US vehicles. There is a bulb in the upper portion and, when turned on, they throw a small area of light directly in front of the vehicle, out to about 10’. This provides enough light for the driver to see a short distance in front of him, but does not light him up like a giant candle on the battlefield. It is very difficult to see the light from a reasonable distance way.
If you mean the notek rear lights- the rectangular box with 4 square lights on the top half - then that was for use as a convoy light. The four squares had a green tinted glass in them. Each pair is set close together ,with a wider gap between the first pair and the last pair. If you were travelling at night and following the vehicle, you used the light to gauge how far away from it you were following - the 'Goldilocks" system. Too close and you saw the 4 individual lights, too far back and you saw only one blended right, but if you saw 2 lights (each pair merged) it was ‘just right’.
The light fitting actually had a flap that could be raised or lowered. When lowered the convoy lights were visible. When raised the 4 lights were covered and two oval, red tinted brake lights were visible - used for day time travel. When the flap was lowered there was a small hole in the flap that was positioned over the centre of the right red light. When the brakes were applied the little red dot could be seen by the following driver informing him to slow down too.
From Squadron signals Stug 3 G Walkaround by Tom Cockle - an excellant low cost photo reference on this vehicle:
As Gino said, the front notek was to limit the amount of light visible too aircraft or other vehicles. The shroud on top prevented the source of the light from being seen from above.
Was only thinking about the front, but, yup, the back too. Modern US vehicles still use the same basic system as well. We call them Black-out Marker Lights. Same basic set-up with 4 slits. If you see 4, you are too close, one and you are too far back. You should see two lights on each side for proper distance.
i also have a question about the convoy light – on my 1/16 tiger I it looks to tubular-- not rectangular as u guys have shown-- is it a different type of light?-- like a black light?— i’m talking about (what i assume to be the light)under the toolkit on the rear left side---- thanks guys[:D]–mr treadwell
Yes that is a different type of light
thanks for the help peter[^]another mystery cleared up for me–thanks again–treadwell
