Non-slip coating
Tracks rule!
Anybody have any ideas on how to simulate non-slip coating on the hull of M1A1/2s? Looking at my (unbuilt) Tamiya M1A1 (the older kit), I’d like to make it look as authentic as possible, using the DML [HA] as a guide. Tried using liquid glue but the small test spot stank.
Thanks for the assist, guys.
Andrew O.
Got the guts to make the cuts?
Welcome Andrew!
I’m a newbie so I’m not sure but I’m sure someone here does. I do know however that the Trumpeter kit has the anti-slip coating already molded onto the hull. Supposedly the the turret is mor accurrate than the old Tamiya kit as well from what I’ve been told. I mayself am too new to know the difference!lol[:D]
Thanks MartianGundamModeler. Trumpeter’s here in Manila but I’m hesitant about buying the kit. Might try it, but I’ll still hafta figure out what to do about the Abramses I got.
andrew,
The closest thing that I can think of is the 3M frosted tint film for glass that comes with a nice texture. It is quite pricey though.
Try getting the Dragon M1A1 or M1A2. They are bout 1/3 of Tamiya’s M1A2’s price but already has the anti-slip coating.
Good luck.
Try placing a small piece of coarse sand paper, face down on the kit, and rubbing the back with the side of an exacto blade handle or piece of wooden dowel. This will you give a slightly roughened texture. Test it first, as you will need to practice the technique to get it right. I have heard some guys say they soften the plastic with glue first, but I envisage a stringy mess doing that.
Otherwise, mix some fine grit with paint and spread that on.
Welcome to the forum andrew_o. Check out this link http://vodnik.net/index_feat.htm. Check the topic : Easy to make non-slip surfaces. Hope this answers your question.[;)]
Nice link, Alex. Thanks
Try to have a look here: http://www.vodnik.net/pages/nonslip/nonslip.htm
Ciao
Fabio
