New Member
Hello and hello
My name is José. I live in Toulouse in France (so I can see a lot of new Airbuses though my interest goes exclusively in military planes). I like to build… tools rather than models (I wonder sometimes if all the models I buy are not in fine a pretext to find new techniques, new painting mixes, new references). I had a step motor controlled turning table in my spray booth, but it was not enough, so I am currently designing another model with three step motors as to modify the aspect of the model while spraying (spraying what, you’ll ask ); well, there is where I find my recreation.
As for nail polish remover mixed with putty, have you tried 95 % alcohol (the one used to dilute varnish flakes and used by furniture makers) as it dries very quickly ?
Thank you all for coming
José
Welcome, Jose. We all love tools; to a varying degree, that is. I think you’ll find a great place in the techniques department of the forum. Hardware is among the common subjects there. Hope to hear from you soon.
Welcome to FSM Jose. Keep us posted on any tool breakthroughs that you have.
Welcome aboard Jose, sounds like an interesting idea that rotating table. It would save alot of hassle while painting.
Ok, in my introduction I mentioned a turning table for airbrushing
I have a little time so let us go for the turning table description. I see here and there a trick to hold the model while airbrushing it and it sounds of "deviant " to me. So I figured out how I could manipulate the thing without ever touching or holding it. I went to an electronic shop and bought a kit to control a step motor ( it is of ITC brand and you can find it at http://www.selectronic.fr or http://www.conrad.com among other places) I am neither a complete rookie in electronics nor a real enthusiast but it is very manageable with little care. Then I took a kind of Lazy Susan turn table of approximatively 30 cm of diameter (yes cm, remember I’m French). You have then to set the turn table near the step motor; I used a piece of wood as a base, a big pot knob with emery board cemented around to screw on the motor axle and rubber foam (rather hard kind) around the turn table; so the control of rotation is very simple and very cheap; you can also set the speed on the electronic card. I settled a DB9 (the kind of plug there was on old PC mouses) as to unplug the table system and clean the painting booth for example.
Advantages:
1° I never touch my model while I airbrush it
2° then my hands are very clean (at least the left one as it is controlling the clockwise-counterclockwise motion by means of switches or an on-off-on tumbler, the right one depends if I screwed well the head of the Aztek)
3° the step motor acts as a brake when it is powered and not rotating
4° why a step motor and not a simple motor ? Because it is very slow and therefore under total control
Drawback
I see only one but it is not to neglect : you are more or less condemned to “attack” the model with the same angle if you use a painting booth, that is why I am currently designing a new table which will be able to keep a constant angle while turning (same philosophy of step motors but more complicated)
As a conclusion I would add that just putting the model on the turning table does not seem very wise in my opinion because it should be raised a little , 8 or 10 cm (remember, always cm) because of the paint which goes to the table and tends to bounce . I have my solution but what do you imagine youselves ?
