Building another 1/48th scale Academy CH-53E. Building this one for a retired USMC First Sergeant I served with back in the 80’s-90’s. He was a “plank owner” of one of the first CH-53E squadrons on the west coast. Marine Heavy Helicopter Squadron 466. (HMH-466) they were comissioned in 1984 in Tustin California, at MCAS Tustin(H). It used to be known as LTA for the longest time due to the large hangars for the airships that were based there. Hangar 1 is still the largest wooden structure in North America. Hangar 2 is not on the historical registry as it is, get this, 3 feet shorter than hangar 1. Google the hangars and you will see, they are HUGE. When I was stationed there, you could have your own weather pattern inside the hangars, fog, rain even.
he requested a 2002/2004 CH-53E with his squadron markings. So HMH-466, YK, BuNo 163078, side No 78 will be his markings. The academy kit, is a “block upgrade” CH-53E depiction. (Starting with the 163XXX BuNo’s from Sikorsky both the Navy MH-53E and eventually the USMC CH-53E’s were delivered in this block assignment)
The engines were GE-416A’s, vice straight 416’s. It has the upgraded tail rotor featuring all composite tail rotor, vice our early aluminum/fiberglass blades. Also it has the modernized cockpit, FLIR, ARC-210 radios, ALE-39v2, APR’s, AFCS upgrade in the lower panel. The new collins CDNU’s for radio/GPS navigation in the lower panel as well. Upgraded more oil resistant soundproofing was installed in these aircraft in the side panels as well as the overhead panels. the old soundproofing was a heavy cloth, but it just SOAKED up hydraulic fluid and transmission oils.
I purchased the Eduard, PE set for this build, and I am absolutely stunned at how detailed the parts are. As a 53 guy I can read and see all of the instruments that I just described above. the seatbelts alone are better than my, ahem, masking tape attempts…so, I will start with the cockpit and go from there.
Looking forward to building this for him, and learning some of the new techniques I have been reading here on the forums.
Next I moved onto the side panels and interior cabin.
The soundproofing is a bluish gray vice the old gray from the early CH-53E. As crewchiefs we would run 550 cord along the litter bracket mounting points, so we could hang our troop seat seat belts up. The kit has the early troop seats with the stanchions clipping into the floor. We went away from those seats after the first gulf war, zero crash worthiness! We went to a new Isreali Aircraft Industries seat that were quick flip up type, dark green and had quick stow brackets, great seats, for troop lifts, then you needed to configure quickly for an external mission it would take seconds vice 20-30 minutes to put your seats up. I tried to replicate the new soundproofing and the upgraded seats, seat bars. In todays CH-53E’s as well as the CH-53K, we have Lockheed Martin individual crash worth seats installed in the aircraft, they are excellent seats and provide 10g crash attenuation for the troops in the back!!
I second the motion - a 1/35 CH-53 would rock. While I’m making wishes, I’d love for Trumpeter (or Bronco) to put out a box of 1/350 CH-53K’s. It’s a mean looking piece of equipment.
Update to the CH-53E build. I have completed all the major assemblies. The batwings are on, as well as the aux tanks are finished. I completed the engines and have painted them seperately and will install once I finish the overall fuselage painting.
Dipped the canapoy in Future floor wax, and then began the finishing assembly
I searched around the forum for some building tips, and I am trying utilizing a white glue for my canapoy install. The set up time was very long, but overall I am very happy with the way it turned out. Smooth, and clear when dried. Very little filler needed, and the Academy kit canapoy actually fits very well compared to the Revell kit for the CH-53D, it can be horrible if the fuselage halves are warped from being in the box for 30 years…ugh!
Onto priming and working on adding details to the rotor head.
Working on the rotorhead now. ResKit and Blackdog makes several nice upgrades for this kit, as well as for the 1/72 CH-53E, MH-53E, MH-53J model kits. Once I am a little more experianced I really want to try and add their resin kit details to one of my 53E builds.
So the kit really lends itself to detailing the rotorhead, and I have seen a lot of outstanding modelers super detail this kit, I am going to try to put some detail into the rotorhead, as this is my first attempt, I am sure I will learn alot for the next model.
I wanted to add the bladefold lines in, as they are easily seen from the air and ground in almost all of the CH-53E pictures out there. Each sleeve and spindle initself is a piece of art work. I have built many of them up for installation on the helicopter. They come bare from supply and you have to transfer all of the hydraulic lines as well as avionics harnesses over to the new sleeve and spindle prior to hanging it on the head.
So I built a mini blade fold manifold out of evergreen sprue and fastened it to the top of the spindle. Next I add the press/return lines from the hydraulic spider manifoild that runs down the center of the MGB output shaft. Then add the pitchlock hydraulic lines to the upper and lower pitchlocks that the kit parts were moleded with. A nice touch as building those from scratch would have been a bummer!
Got the helicopter into the paintbooth last night. Primer and some more sanding was completed. I have noticed that the white glue I used on the canopy has seperated after complete cure, even though I tried to tack it in place. I guess I did not account for shrinkage of the material as it dried. I will address this tonight with some filler and light sand, prior to my next color the dark gull gray.
I am trying a a technique I have watch a few videos on and also have seen here on the forums of pre-shading the panel lines. I guess I am an old school guy when it comes to weathering, the pastel chalks, and using a thinned down black enamel are over. There are so many great things out there now. Tamiya panel line, AK weathering pencils, Tamiya powders, artists oils…on and on!
I learned a lot when I did this. I used a light gray primer, then I came in with my airbrush at around 20-25 psi with a thinned enamel model master black, and etched my panel lines. However when I came back to my base color and tried for the effect I did not fair so well. The light gray and the gull gray made it very difficult to accentuate the panel lines the way I have seen a few youtube videos. PRACTICE PRACTICE!! I am going to re-watch the tutorials, and get this right, as I love the effect you guys get on weathering these gray/gray modern color schemes.
learning is the key here, I’d love some feedback from you all, on both my canopy faux pas, as well as the shading techniques you like. A little look at the overall airplane as she sits on the bench awaiting some more attention.
I tried the white glue on canopies a long time ago and gave up on it. They were not that tight when dry, shrunk as you have experienced, and tend to pop off when you pull the masking tape off. I sparingly use super glue on all my canopies. If I get any frosting, rare, I lightly hit the area with gloss clear on and angled brush that I use to get into hard/tight areas.
I am not a fan of the pre/post shading of panel lines. I have never seen a real vehicle or aircraft where the outsides of the panels are darker than the insides. I stick to the tried and true washes, drybrushes, and pastels for weathering as well. All the new-fangled fads don’t look realistic at all to me.
Excellent advice on the canopy situation. I will go back to superglue, I too have not had a frost issue when I use it sparingly with a toothpick or needle.
Looking over your builds I admire your weathering very much. I too “grew-up” with washes and pastels, and have had great success in creating that realistic appearance with that approach. Being around military aviation as long as I have, and seeing the colorful paint jobs of the 70’s & 80’s and now onto the subdued paint jobs of today, I have seen all kinds of weathering, shading, mis-matched paint for sure!! The CH-53E lends itself to heavy weathering, as the GE-416A’s and -419’s are sooty turbo-shaft engines, and the airplane itself leaks everywhere. There’s just not much we could do about it. The subdued gray - camo paint “soaked” up all the grime, and oil stains.
Thats why the last deployment of the CH-53D’s to Afghanistan the aircraft were not flat gray any longer. They were a semi-gloss, and sometimes gloss gray when they returned from the rework depot in Japan to Hawaii. Easier to keep clean, and wiped down.
I guess weathering is a perspective of the model builder, and I am sure lots of opinions on the subject. But, like you, I have been around some fairly dirty, weathered Army/USMC gear, and when the weathering is just right, the model really pops.
Hey Gunny, your helo is looking great. I wish I had one. I built up Revell’s HH-53C and would love to have a USMC Echo too. I just don’t know if I have the space…or the cash!
Anyway, I wanted to share my two cents about painting modern USN and USMC grey schemes. By no means am I a pro, but I tried something on a Super Hornet I built and was happy with the way it came out. It’s called “black-basing”. There are a ton of “how-to” videos on the web about it, but here’s how I did it in a nutshell.
As far as what I did, it was pretty basic. First, I primed everything in black. (Duh.) Then, I sprayed the lower color, the lighter LGG, first. I thinned the MM enamels to about 50/50 with some laquer thinner. I sprayed it at a low pressure, about 15 psi, with my airbrush pretty close to the surface. The paint was sprayed in a random pattern and the goal was inconsistent coverage. I shot one panel at a time, in a completely random, almost “squiggly” pattern. If I wanted a darker, dirtier, more mottled look, then the base color was sprayed more haphazardly and the coverage was more inconsistent. If I wanted a cleaner “greyer” look, then I made sure the coverage was more consistent and complete. The upper DGG surfaces were approached in the same fashion. Once I was happy with the overall coverage, then I sprayed some DGG “splotches” on the lower lower surfaces, and conversely, some LGG splotches on the upper surafaces. I didn’t do any “lightening” of the base colors. It was all about coverage. Besides those two greys, I picked some random greys and shot them in random places and with random coverage to give that beat-up “touched-up” look to my airframe.
I avoided pre-shading the panel lines because, to my eye, I didn’t see that “pattern” in reference pictures. If I had to do it again (and I will), I think I’ll use thinner paint and a more random spraying to give the modern airframes a more “operational” look. Maybe even go back with a lightened base color and spray more splotches into the center area of some panels. The great thing that I noticed about this techinique is that, if you have to go back and fix any boo-boos, and/or do any spot touch-ups, all of that will add to the overall effect of the paint.
I hope this helps. Good luck with the rest of your build. I’m looking forward to seeing this monster all wrapped up.
I can’t say I trust superglue not to fog the canopy, and it’s hard to fix if it’s on the inside. I think the most important thing is to work at the fit for a while, and use Future.
Then use either styrene cement or CA very sparingly.
Gino, second you on panel shading.
O has excellent, high level advice. I suggest yoiu not try this first time out on your Stallion, but on some trash model.1/32 53? Well, I built five of them for my Tarawa, at 1/700 and they were sizable.
