A new build but what could it be? Cutting first plastic last night preparing for inserts.
I need to remove all 16 of those panels for this project. When this part is complete it shall be done in wood tones with iron accents.
That’s cool! Are the open panels your own mod? To be covered with something translucent?
There is an aftermarket for this which just came out a few days ago. Here all the panels are now removed
Now some photoetch is being laid in. I think I’ll be filling the areas inside the main beams. In the end there will be LEDs involved.
Well, the hint about recently released photo-etched parts tipped me off. This is the Nautilus, from Jules Verne’s 20,000 Leagues Under the Sea. The basic kit is made by Pegasus Models; it and the photo-etched set are listed by Freetime Hobbies.
I’ve seen quite a few models of this fictitious submarine over the years. The only thing that makes me raise my eyebrows a little bit is that all the kits I’ve seen have been based (more or less) on the ship in the Disney movie. It’s a fun movie (where else can you hear Kirk Douglas sing?), but the ship is the invention of the Disney designers - not Jules Verne.
Quite a few years ago the Naval Institute Press published a beautiful edition of 20,000 Leagues Under the Sea, with superb reproductions of the engravings that appeared in the original edition (or one published shortly thereafter - while Verne was alive). The pictures show the Nautilus as a very simple shape - more-or-less a cylinder with pointed ends. The text of the book describes something similar.
What we’re talking about here, of course, is a completely fictitious subject, so no normal criteria of accuracy really apply. And the Pegasus version certainly isn’t identical to the ship in the movie; it looks like the kit designers added a good deal from their own imaginations. The modeler surely ought to feel give his/her imagination free rein on a project like this. I do think, though, that it’s appropriate to acknowledge the genius of the Disney people alongside the genius of Jules Verne.
This kit is ‘inspired by’ the Harper Goff design used by Disney. Since Disney holds such a tight grasp on the license it’s extremely unlikely that any company will do a production injection molded kit, just not fiscally practical. You are right in that the Jules Verne sub was described as a very utilitarian cigar shaped vehicle but come on, who can resist a good Steampunk sub? Now I just need a Fichtenfoo Squid sub to go with it!!!
I’d like to find a model of the 1930- 1931 Wilkins Nautilus.
Matt that’s a nice project and animation will do her proud. Eager to see this go forward.
BTW I stole a look over on Swanny’s and discovered what you are up to, but didn’t want to give it away…
Heh heh, that’s cheating!
The ceiling section is done (other than the actual lights) and I’m ready to look at the floor.
Here the viewing sofa is in place. I’m working on other kit included details plus some other items to flush things out.
Very nice Matt. I picked up my copy at Wonderfest the other week. I didn’t get the aftermarket PE, tho.
I really like your rugs. I’ll have to make some for mine.
I think some velvet curtains are in order.
Will you be using the Kraken for your display base? I’d like to use it, but I want to light mine up as well, and I’m trying to figure out how to wire it through the squid.
Go to Radio Shack and look at the very fine magnet wire. It uses a lacquered insulation rather than the thick plastic we normally think of. As such it is very easy to hide alongside one of the squid arms. I’ll be doing that on mine but another idea I had was to pick up some plastic tiny vines from the craft store and add them as seaweed and run the magnet wire through them.
Thanks Matt, that’s a good idea. I used that kind of wire when I put lights in the engine nacells of the Enterprise D.
PROFFESSOR !
I am amazed you missed one ! There is a PAPER model based on the description in the translated first edition of the ORIGINAL FRENCH printing of this great book . This model is put out by DEUTSCHES SCHIFFARTSMUSEUM . It is definitely based on the book . It somewhat resembles the DISNEY boat , BUT , there are very many large differences in the design . I got mine from PAPERMODELS INTERNATIONAL some years before they went bottom up .It is in 1/100 scale and has the FULL interior . Most (darned near all ) of the writing and parts listings are in GERMAN , but , she’s fairly straightforward in build sequence .
Now , this one is so fascinating , it behooved me to start using the sheets as patterns to create her in plastic .I have the plan drawings done and now I have to transfer it to plastic sheet . I intend to build her out of .015 sheet .Why ? well the paper is almost .010 cardstock thick .I figured that going to .015 would be wise while staying to the purity of the design .I will use a LOT of found parts and brass in her build .the organ for instance is a organ from a keychain type thing with real brass sound tubes . I will tell you this much .This PAPER model is fully color printed including the metallic finish on the hull .There is an exploded drawing inside the back cover showing the thousands of parts .Yes thousands . I think there are at least fifteen hundred parts .
The other nice thing is the full color picture of the model on the cover AND the period art on both the inside and outside of the parts book . If interested , I think P.M.I. may be in business again , I am not sure .here’s an address for any who wish to buy it direct ? Gedruckt mit Mitteln des F’or’derveriens Deutsches Schiffartsmuseum e. V. 27568 Bremerhaven . P.M.I. also gave you a description and building hints on a loose page inside the book . Just a reminder , this sub is based on the 1870 printing and artwork . Check it out ! Thanks for being our Proffesor in residence . Tanker-Builder OOPS ! I forgot to give the full title on the front of the model book .It is Unterseeboot NAUTILUS , erdacht 1870 f’u’r Kapit’a’n Nemo von Jules Verne Also forgive the attempt at umlats .I don’t know how to get this computer to do that .
I would love to see a scan of that artwork.
This week I am working on the ventral fin area. In the middle of this ‘fin’ is a set of large grills, the PE set includes a replacement set of grills for this area. I want to introduce a dull red glow inside this area so am removing the inside plastic, adding some base color paint before attaching the new grills then will work on adding a lighting effect here.
Thanks for the update! What color are you using for the base, brass?
Neat stuff there, Swanny!
The base color is Alclad copper.
