Need helping ID'ing IJN AA gun and placement
Greetings, I have recently purchased the Tamiya new tool Yamato and the accompanying Lion Roar up-detail set. I have gone through and marked where each instruction intersects with the other except for one item. The Lion Roar has an AA gun that I can’t find in the Tamiya instructions, and furthermore, I can’t ID it, nor where it should be placed on the Yamato. I scoured navweapons.com to no avail and wondered if any of you might have an idea;
It only calls for two of them, but I’m at a lost as to what they are and where they go, any ideas?
Thanks!
That looks like a twin barrel Type 93, 13.2 aa gun.
I’ve no clue where they go. Skulski says “either side of the tower bridge” whatever that suggests.
Wikipedia: Yamato-Class Battleship
“The ship was also provided with two twin mounts for the licence-built 13.2 mm Type 93 anti-aircraft machine guns, one on each side of the bridge. The maximum range of these guns was 6,500 metres (7,100 yd), but the effective range against aircraft was only 1,000 metres (1,100 yd). The cyclic rate was adjustable between 425 and 475 rounds per minute; the need to change 30-round magazines reduced the effective rate to 250 rounds per minute.”
You guys are awesome, many many thanks!
To finish this odyssey it seems that the AA placement is here, per the Kure museum model (mirror on port); Again, thanks much!
Excellent! At least y’all found good photo references, I’m struggling interpreting features from less than half dozen photos building two floatplanes, they’ll have to do.
This has been a lot of fun to participate in.
I’m not an IJN fan, although I have a Kagero Class Destroyer sort of going.
The thought of building a Yamato/ Musashi is the stuff of nightime flop sweats…
That museum model is a thing of beauty. I really like the armored bridge (citadel) way up there on top of the tower.
Intereresting thing about that model is all of the larger caliber guns that are removed from their turrets.
So when RIK says licensed built, it was Hotchkiss.
The author I referenced was of the volume of Anatomy of the Ship. Always worth owning.
:smiley: my last build was the Trumpeter Texas and I went a bit AWOL trying to locate proper life raft positions for measure 22 off Normandy as I just didn’t have many pics to work with, I feel your pain :smiley:
This was to put off my Titanic build :smiley: …again
Didn’t know about the book, it has now been ordered, thanks!
