Need Help on Purchasing a Paint Booth
I have a airbrush on order that I will receive in a few days . I realized by reading on this forum that for saftey purposes I should get a spray booth. I want to be sure I buy the correct one that will protect my family and I.
My work area is in the storage part of my basement which also contains the furance and hot water tank that run on natural gaz. There is a door that connects this room to the finished part of my basement were my kids play and watch TV. Often I am working on my model when they are in the other room, which is only a few feet away. I have a window that is directly above my workbench.
I saw a metal Paasche spray booth on ebay that has a motor and is equipped with a duct to vent the fumes outside. I assume that all I have to do is run the hose from the both to the open window. One dilema is that living in Canada it gets mighty cold in the winter, which could affect the paint properly adhering to the plastic. I guess I can bring up the temperature by using a space heater.
Will this type of spray booth eliminate the harmful fumes? The price is $179.00 U.S is this a good price ?. Don’t convince me to build me own , my handyt work begins and ends with model building.
Personally, I think you’re doing the correct thing: purchasing a manufactured spray booth. Just a couple suggestions:
  1. Go to the Paasche website: www.paascheairbrush.com and look at the booth specifications. What are the dimensions of the booth face ( the opening into which you will be spraying)? Second, what is the rated cfm of the fan? For example, say your face dimensions are 2’ X 2’. That’s 4 square feet. If you try to maintain a 100 fpm airflow at the face, then 4 X 100 = 400cfm. Therefore, the fan should be pulling at least 400 cfm. (In actuality, airflow at the face should be about 80-100 fpm to allow for adequate vapor capture.)
  2. Fan speed is also important when exhausting the vapors that accumulate inside the booth. Since you are pushing the vapors upward, the fan has to be strong enough to get them out your window. You can help the process by keeping your ducting as short as possible, and avoid a lot of bends, especially right angles. Length and bends all add up to increased resistance, and therefore, a fall-off in duct transport velocities.
  3. Use aluminum flex duct as your exhaust ducting, NOT dryer hose, as the latter will melt/burn, and may react negatively over time with solvents. The solvents may leach out the plasticizers, and leave you with a brittle mess, forcing more frequent replacement, or at least vapors that escape through small leaks before getting through the window.
  4. For comparison/pricing sake, go to www.micromark.com and
    www.artograph.com and look at their booths and specifications, and see if you are getting the best booth for the least amount of money. It never hurts to comparison shop.
  5. Once you get your booth set up, get a small ABC fire extinguisher and put it under your hobby bench. You will probably never need it, but It never hurts to play it safe.
  6. Lastly, have fun…and let us know what your decisions are. If you have additional questions, don’t hesitate to post here, or e-mail me.
    Gip Winecoff
