Need C-46 instructions
Does anyone have a scan or a copy of the instructions for a Williams Bros. 1/72 C-46? The particular version doesn’t matter. I just got an old kit and it looks like the dog ate the instructions or maybe died trying because here’s what’s left of them and I don’t know if those brown marks are blood or what!
I will look and if I still have them and send them. there’s an error you can see on yours, which is that the landing gear has the strut on the outside where its on the inside.
Great model; two thoughts.
Skip the interior floor, it doesn’t fit and it can’t be seen unless you cut the load door open which would be a challenge. Also, the kit glass IMHO is better than the aftermarket bit, but it comes in two halves, neither of which fit. Put each individually into its half of the fuse which involves some shaving of plastic down around the pilots knees to make it fit. Then glue in. The center joint is a painted frame anyways.
If you build this you’ll have a top twenty kit, IMHO.
EDIT: found them will email tomorrow.
The floor is a major problem in the old kit. It has been corrected in the re-released version. Squadron makes a one-piece vacuum formed canopy. It fits much better than the two-piece canopy which comes with the kit. I used it when I made my model.
Kenjitak PM inbound.
Thanks for all the info. Here’s a photo of the C-46 I want to build. It’s a “tanker” that I saw up in Alaska named “Maid of Money”. These guys have put a big flexible fuel cell inside the main cabin and fly around delivering gasoline and jet fuel to the small gravel strips all over Alaska. We were doing field work in ANWR when they landed. The pilot got out with a fishing pole and fished for Greyling in the river next to the strip while the crew pumped out the fuel. They all got a bite to eat too.
Thanks again Bondoman. The scans came thru my email perfectly!
