Need a better workbench
My workbench sucks and I’m brainstorming for ideas. Any suggestions? What type of table and where can I get it?
I can make a ton of suggestions but without specifics as to what you build, how much space you have, do you want to stand or sit, enclosed/open, kids or none…all apply to what recommendations to make.
You can see what I and others use both (past and present) by visiting my post Work Bench Overview Pt I and Pt II.
The workbench like shoes has to fit the user to be comfortable as well as functional.
I bought an old L-shaped desk for $25! It has 7 drawers and it’s plenty big enough for what I work on ( 1/48 aircraft mostly ). I drilled holes in the top to mount my lights since I couldn’t clamp them to the side. First you need to figure out how much room you have to work with, then decide what you want in a work table/hobby bench. Good luck!
I bought a 42 x 24 drawing table and use it for a bench… I added drawers that I picked up here & there… The table cost me 60 bucks at Hobby Lobby (with 40% off Coupon)
i use my old computer desk…works great for me!! here’s a partial view of it!
I bought a computer desk from Ikea. Paid about $150 for it.
I use an old metal office desk that I picked up at my employer’s surplus store pretty cheap. The drawers are a bit deeper than I prefer, but there’s a lot of volume to store stuff and surface area to work on.
My dad set up a pretty cool general-purpose working area in the garage using the kitchen cabinets (which were being replaced with new ones anyway) and then laying a preformed laminate countertop over them. He left a gap between the lower cabinets so that you could sit there and put your legs underneath, but hardly anybody actually sat there for any period of time.
You may also want to check out used furniture stores to see if you can find a table/desk that’s the size you want… Not much purpose in buying new something that’ll potentially get hit with the various mishaps of modeling (spilled paint, knife marks, etc.)
Build it yourself,that way you can make it exactly the way you want to. Thats what I’m is the process of doing as I get money. mine is L shaped 5’ main work area and prob. gonna be 8’ on the other wall to hold my spray booth and machine tools. When done I will snap pics. I will also prob. use my old Craftsman box similar to what Hawkeye did since theres not much in it any more,I upgraded to a Snap On box years ago. Let me know if you need more sugestions I have all kindsa crazy ideas in my head,this is the last bench I want to build.
John
I built mine a year ago last spring. I only had a small room for my hobby area so to get the most of the space I used a “L” shape. The inside legs are set in 4" to not be “Knee Whackers " or “Toe Stubbers” The Material used was 3/4 " Birch Plywood, 2” x 2", and 1" X 4" lumber cut and ripped to size. Less then $80.00 invested.
All the building takes place on the right hand side. The spray booth in the middle works out Very Good for me. I mix paint and do the decal’s on the left side. My Teenage Son has also been known to build on that side. [^][tup]
Bench
Try to get as much storage space as you can. Can’t have too much of that!
AMEN!
Agreed on the storage space issue.
A few years ago I decided to scrap the two separate units I had scratch-built but were portable and didn’t provide ample space for a permanent L-shaped unit. I designed it for maximum space, both top side and underneath. It runs about 6’ down one leg of the L and 8’ down the other. I put in a custom drawer unit that I am not real happy with (am considering buying yet another Craftsman tool box to install in that space).
I added an old metal workbench I had to form kinda a “U” shape where I store most of my unbuilt kits and paints/tools.
If floor space is something of a premium, look at a corner computer desk. Mine comes with storage areas on both right and left sides, plenty of workspace, and I put my various toolboxes under the desk at the sides (where they are out of my way, but easily accessible). There are also shelves on both sides for my paints and various supplies. They are cheap!
Good luck!
This was my workbench until last Feb when I moved into a place that had a second bedroom for me to turn into The War Room…
It was really nice moving out of the living room, lol…
now thats my kind of room! i have an ikea desk at the moment, but i’m going to convert my garage(soon to be known as the outhouse/bungalow) into a workroom with a big L shaped workbench.
once the new concrete floor has been put down and i’ve put in a couple of extra windows i’ll build the benches.
MZ, I built mine from a damaged solid core door that I paid $10.00 for at LOWES. Then I bought a couple of storage racks (200#cap. each) at WAL-MART and attached them to the bottom/underside of the door with electrical conduit wall anchors, then crosstied them with a wire rack shelf piece that I had leftover from another project. All in all It cost around $30.00, and is solid as a rock. Then I built a paint rack and paint booth. It sure is nice to have a dedicated build area after all these some 45yrs. of building models on a kitchen table.
doc
You don’t really need anything really heavy for modeling, and I also building one too. I was over at my son’s house the other day and he had a stack of old flat panel doors in the garage that he’d replaced with six panel doors. They’re 24" wide (some were 30" wide), and about 80" long. Of course they all had a hole in one side for the door knob, but for that was OK to run the wires for lights and a power strip. Anyway I’m going to cut the door off at 54", and then use what’s left for an “L” shaped bench top. Or more that likely just cut another door and make the side side 54" as well. The one real problem I ran into was that these doors are the hollow type, and I’ll have to make a filler strip for there I cut the doors. I’ll then screw them together from the underside, and them buy a couple pieces of hard masonite for the top. Then I go over to Lowes and look at cabnet bases in the unfinished section. They have just about anything you can think of. Also in the center (where the two panels join) I’ll need to make somekind of the frame work to support all this, and have decided to actually screw the cabnet bases to the frame work. Right now it looks like I’m going to use either an 18" or a 24" multi drawer cabnet on one end and a 12 or 24" one on the other end. The worst part about this project is painting it!
gary
I built mine from salvaged/scrounged lumber, I think the only thing I bought was the stain and urethane varnish to color and seal the work surface.
Here are some shots of it (I apologize for a duplicate post):
That was taken over Christmas vacation, but it still looks pretty much the same. Before I bought my house, I was living in a mobile home, saving money for a house. This bench was carmmed into a spare room that was about 10’x10’, and that determined the dimensions, it’s about 4’x8’.
As you can see, it’s oil-fired, to power the Dremel. Note the tank behind and the burner to the right…No, just kidding! It’s in the utility side of my basement.
2x4’s for the framing came from a theater I belong to, when we struck a set, and the work surface is made up of 4 pieces of 3/4" plywood shelves that I got at work (they were being thrown out).
I’ve since added two more legs about 2’ in from the left end of the table, front and back side, and a rail on each, to support some pine board shelving. That holds more of my kit stash. The rest of the stash is behind the camera’s position.
I’m thinking of adding some shelves along the back of the bench, to add more storage for things that I need to access, but are currently on the bench itself and in the way.
It’s true, isn’t it–you always need a bigger bench…
This is a nice topic. I’ve been planning on building in a corner piece in my study specifically for modeling and model building. Right now I’m using my office desk and its working fine, but I don’t really have room for all my tools, paints, etc. to be readily available. Everything is just shoved into drawers. Plus, its not really condusive to trying to have a home business with modeling stuff everywhere.
I’ve already started building in bookcases along all the walls and plan on adding in a display cabinet in the future. My desk sits in the middle of the room facing towards the entrance opening (there’s no door, but rather an 8’ opening into the room). I plan on building in a corner cabinet behind the desk so that I could just spin around and work rather than move to another part of the house. I also want the piece to be completely self contained … in that once everything is folded/ closed up, it just looks like a reular corner cabinet. However, on the inside, I plan on have magnetic tool strips, racks for paint bottles, lights, power strips, shelves for reference books, etc.
I’ve got some “plans” drawn up …I’ll try to scan and post them later.
Thanks again for the thread!
I use a long plastic table, the kind you’d see at a flea market or at an outdoor buffet kind of aprty thing, you know the tables I mean. I have 3 areas set up on it. The one right next to me for quick painting and such, one with my cutting mat for when I need to do specifc tuff, and my AB/spray painting area all on the same table. I have a little thing with drawers at the first part, with all my tools and paints in it nice and organised.
