hey got bored of my other builds and started on this one lol
since its a DEI truck I couldn’t resist using the cool valve cover decals.
I swapped out the quick change rear end for a 9 inch.
seat detailed
I have glued in the engine now.
for my braided hose I use solder and stretched sprue for the fittings.
in the engine bay I will add heat shielding to the lines. and where I dont I roll the solder on a file to give it the braided texture
AWESOME looking build so far. Can’t wait to this built. I specially like the Valve convert with Dale Earnhardt Sr. signature. Great detail. [Y][Y] [t$t]
Do you use oil paints to do all your shading, staining, etc.? I’ve always painted a darker base coat and then painted lighter coats on top. Your method seems so much nicer and easier (at least if I’m correct in my assumption.)
I spray paint everything if its simple colors like black or metal finishes. airbrushing if i have to mix up a color, but ya i dont brush paint anything
