I have seen some really great dioramas from everyone. What makes some of hem really standout is the way they are name on the display bases. I’m doing nothing but dioramas and there coming out pretty good but I’ve held off putting names to them. How do you make up the name plates or any other method that I have seen. Any help out there?
I don’t know if you were looking at some of my displays or not, but here’s how I do it.
I just print out a sign using Word and glue it to card stock. Trim and attach to the base.
Steve
You might be better off putting this in the dio section, you should get more responses.
I print mine off on card. I make the image on paint.net then save it and then put it into a word doc so I can make sure its the right size. For some reason, when I set the image size on paint, it comes out a bit smaller. Once its printed out, I then put some clear sticky plastic over it (the name escapes me at the moment) then stick it to a piece of balsa cut to size and stained the same as the edging. After that, put some holes in and I screw it to the base.
Just decide what you want on the name plate. I usually have a national flag and then some sort of insignia that relates to the subject with the aircraft/vehicle name in between along with unit details.
Here is a couple of examples.
Hope that helps.
I only started doing it last year. Before that I used rub off letters straight on the wood. But they were a real pain. I could never get them all straight and if I messed up I had to start over. And sometimes they were hard to see. But after seeing what others did on here I decided to switch to these.
I like the look of yours. But for some reason I can’t get them right when I use word, so I do them on paint.
I never thought of using Paint. I figured out to use paint to get all my badges on me signature line, (whenever I display them again) so it should be easy enough to make a sign using it.
Also, after seeing yours, I need to come up with a way to stiffen mine up a tad. I like the plastic covering. It’s a fine tuning process.
I do need to replace some of my earlier ones though.
I use the plastic more to protect the cardboard, but ye, it does stiffen it as well. I use the stuff used to cover maps, it come sin large rolls, but I still can’t recall what we called it. Mine could go straight on the wood surround, but I like them to stand put a bit.
I don’t know what fonts you use, but I found some you can download and work on paint. I now have a couple of German style fonts which I will now use instead of the old English and the F-16 is a USAF font and I also have a WW2 style USAAF one
I also like the division symbols you use. The SS, Africa Corps, USAF, Luftwaffe etc.
I learned the whole sign idea from you, you know.
Thanks. I think it just adds a little more interest to the subject. It took a while to decide what to do for my modern USAF builds. I wanted something similar for all my modern US aircraft and when I found this, along with one for the Marine and the Navy, I decided to use those. For German armour not in Africa I just use a pretty basic Wehrmacht eagle in a shield as that was the most appropriate I could find. I have a couple for other I haven’t used yet but I think I have a pretty god collection now that will cover all my builds.
And thank you, its nice to know its nice to know you are helping others as well as learning from others.
Bish I really like the way you do yours with a flag or emblem in color, BTW there are some darn good looking models there between you and Steve.
Terry,
Don’t let us fool you. It’s just another post where we can show off our builds.
Fire 217;
You should post the question in the Dioramas section. You’ll get more responses.
This section is really meant for asking technical questions about the forum itself.
Looks like you got some good responses.
