I do use a rotary tool (Dremel in my case) for roughing out and hollowing, especially on wood abd resin pieces. However, for fine sanding I do it by hand. Much safer, better results.
I agree with Don- a rotary tool (I also have a Dremel) is very handy for sanding away significant amounts of material in a short period of time. Fine sanding- filled seams, for example- yields better results if done by hand.
You will not be pleased with the results if you try to use that as a sanding tool on plastics. It will eat through the plastic and probably melt some of it. Way to many RPM’s.
I use one of the cheap $10 electric rotary tools combined with a dimmer switch to get the RPM’s down.
I do not know if using a dimmer switch with your rotary tool will damage it.
I also use a “Sonic Scrubber”. Its basicly an electric tooth brush on steroids. I use velcro to attach sanding pads to the head of the scrubber.
A good speed control is a tremendous asset. I find the latest Dremel rechargable tools have excellent speed controls as they come. I can adjust it so the shaft is turning over slow enough to count the turns! Even for roughing out a piece of basswood or resin I never run the tool at full rpm.
Don, do you have a model number on that latest rechargeable? They seem to come out with a different model several times a year. The last three versions I bought I returned after getting them home and find they had way to many RPM’s. Yes, I can read the specs on the box but I have to try them anyway…just in case! Sounds like the one you have is what I have been looking for.
