Looks pretty good. Nice work on the flash suppressors. I Like the PE sight. On the gun, in hte middle below the guns, there’s what appears to be an access panel with hinges. Replacing the handle with sprue or wire would lliven that up quite a bit.
I like your concrete! Looks nice and weathered without looking ruinish (like that’s a word [:)]) What is the concrete constructed of? What colors did you use? I have not done a dio with concrete yet but that is comming. Nice work. Oh… and another thing I like is that it has depth. It’s not just all flat. Can’t wait to see it with the figures in it.
Ow, I’m sorry, am I not behind spesific enough, I met dow did you do the hill, the ELEVATION, GROUND LEVEL, HEIGHT, RAISING THE GROUND. I may want to know it for futur project, do you understand.
I’d disagree with this. I think the guns look good. These guys are obviously in a relatively quiet area (just before the invasion, maybe?) so they would have time to keep their weapon clean. The gun barrels are discolored enough (from what I can tell from the pictures) to suggest the weapon has been fired, probably quite a bit, but there is enough down time for maintenance. About what you would expect since these guys are in a fixed position and not constantly manuevering.
What I want to know about is the concertina wire. How did you do that? Is it something you bought or scratched?
looks great, some nice detail on the bike, and the peeing figure really gives it a “snapshot in time” sorta feel. One suggestion, your grss to me kind of looks like clump, all the same colored lawn grass or astro-turf (fake grass). Other companies make static grass which can be used to look like longer wilder grass, and has some variateion in color to look natural. HTH
