I usually build armor but decided to give an airplane (sort of) a try. The last time I did an airplane was 20 years ago. I actually built this one in it’s original release when I was 16.
I did the kit out of the box except for the nacelles. I modified them to be slightly rotated forward as if in transition. The stripes on the blades were masked and spray painted versus using the decals.
I know this model isn’t upto current Marine Corps specifications, but I just wanted to try an aircraft.
Thanks. It’s the old Italeri V-22 kit in 1/48th scale. It came out about 20 years ago, I think. Italeri “updated” somewhat but the decals and the cockpit are wrong.
Thanks. The base is really simple. First, I bought two aluminum tubes. One tube is slightly larger in diameter than the other so that the smaller tube can slide into the bigger tube. Next, I glue a large cube of styrene inside of the fuselage. Then I drilled a hole through the fuselage and through the styrene cube to fit the larger tube. Next, I glued a small section of the larger tube into the styrene. I did the small on the base: drill a hole and glue a small section of the larger tube. Lastly, everything was painted black, the smaller tube was insert into the base and other end into the model. Works out nice since I can easily remove the model from the base.
If my explanation is confusing, let me know, I’ll take some pictures.
