Can someone please tell me if the top section of the P-51d’s encine cowl was removed in a single unit, both left and right side or could they be split and only one side removed with the other side still attached to the airframe?
Thanx
Theuns
Thanx
Theuns
Split, according to the Tamiya 1/32 model. The panels are held on by magnets on the model, and can be removed separately.
OK, I see what you mean. The upper cowl is split down the middle.
I only now saw the top spine where the cowl attaches to the airframe has 2 rows of camlocks, so it would be reasnoable that sometimes only one side of the top cowl was removed?
Theuns
Perfectly reasonable. If what was broke was fully reachable from one side, you wouldn’t pull both cowls.
I would also think that in korea in the winter you would not want to expose the engine bay to snow if you did not have to, only work on the side you really need to work on ![]()
Theuns
