Hi Bill
Thought I’d throw my in[2c] worth.
I glue torso and legs together with cyano. Then I glue the arms on using poly cement, making sure that they sit naturally on the figure and in relation to the vehicle (nothing worse than daylight under a commanders arms as his vehicle is sliding down a 30+ degree slope[:p]… Then again he could be imitating a roller coaster rider).
Using poly for the arms gives you plenty of time for adjustment, and if you let the glue soften and then push the pieces together you get a little bit of plastic to ooze from the join that you can trim later making less need for putty.
Depending on whether you can reach the equipment to paint it or not, glue the equipment down on the figure. For AFV crewman this usually consists of little more than a pistol in holster. If you are worried about geting paint on your perfect camo suit, then just Blu-Tack (Silly Putty) around the piece to be painted/dry brushed to protect the uniform finish.
I drill a hole in the bottom of the figure’s foot so I can glue some wire in it. This means that all you need to do is snip it off later…and no need for clean or touch up. If the figure is going to be standing on a dio base and not in the vehicle, then you can actually drill a hole in the base for the wire to go into…killing 2 birds with one big rock. Use the wire to hold the figure whilst painting.
You can also drill holes, a little bigger than the wire, in a block of wood so that you can put the figures aside between coats of paint and they (hopefully) won’t get knocked over. If you place an empty jar or can over the figure you can keep dust off while the paint dries too.
The head: I always drill a little hole in the the neck and put wire in that too. If the cap is moulded separate, make sure it is a good fit first, but paint it separate. It’s just so much easier than trying to paint an Officers cap when the cap is already glued down on the hair.
It is also a good idea to see how loose the cuffs of the figures jacket are supposed to be. If fairly loose, then I cut off the hands and drill out the cuffs. Wire the hand as above, but use some milliput or something to mould the arm longer, just enough to go up the sleeve. Paint the arms separate and glue them in the sleeve when all the painting is done. You can cut off a moulded on head, lengthen the neck and paint it separate too, as the collar is usually moulded too close to the neck on plastic figures, but these guys didn’t wear ties to battle[:D]
If you like the finish of figures, you will probably progress to changing all heads to aftermarket items, when you see the difference in the result.
