Mr Hobby Aqueous Paint Questions
I’ve been brush painting with Tamiya acrylic paints for a few weeks now and I really enjoy them. I used them to make a pretty good looking F-35 (https://youtu.be/fFx7Q3veOFQ)
I’m currently working on a Bf 109 F-4 trop, I was going to brush paint it with Tamiya acrylics but I’ve noticed that Tamiya doesn’t have any RLM colours. My LHS has the Mr Hobby Aqueous line which has the RLM 78 and 79 I need to complete my Messerschmitt. Before switching to this brand, I want to ask a few questions.
  1. Straight out of the pot, are they thicker or thinner than Tamiya acrylic paints?
  2. Since they’re Alcohol based just like Tamiya’s, can you use X-20A to thin them?
  3. My LHS only has Mr Retarder Mild, will this will work with both Mr Hobby Aqueous and Tamiya Acrylic?
  4. If Mr Retarder doesn’t work, can I use Tamiya Retarder for Mr Hobby’s Aqueous paints?
  5. Tamiya acrylics adhere really well to bare plastic, do Mr Hobby Aqueous paints have the same “bite”?
Thank you to those who answer my questions!
PS. All replies that talk about Mr Color Lacquer paints will be ignored.
Why not use Model Master Acrylics brand instead? They have a wide selection of RLM colors.
I live in Asia and Testors products are nearly impossible to find. Thanks for the help anyway! [:)]
Thanks! I’m gonna pick up some Gunze paints at the store today. [:D]
I think that you will like the Gunze Aqueous paints. They were a favorite of mine. And they have an extensive line up matched to various color standards like RLM,BSC, and Federal Standard.
I really like their Mr Cement S so I’m optimistic about these
These paints are all I use. Don’t use a retarded with them. They don’t need it. They take a bit longer to dry than Tamiya acrylics anyway. 90% ISO alcohol works good for a thinner also. I order all my Gunze Aqueous paints through BNA Model World so it’s good you can get them at your local shop.
Mr Retarder Mild is formulated for the lacquer based Mr Color range. I haven’t used it so I’m not sure if it works with alcohol based acrylics (ie. GSI Creos/Gunze Aqueous & Tamiya acrylics).
The Gunze Aqueous and Tamiya acrylics use a thinner which is based on Iso alcohol and propylene glycol, which acts both as a co-solvent and a retarder.
Ah… that explains everything. :))
