Hey all.
How about if we post our tips, techniques, AM parts & links here on how to improve Motor Bike Models. I see many tips for cars, tanks, planes, etc but few for Motorbikes as such.
In recent days many have talked about opening of air-holes on Brake discs for models where this is not done by the kit maker.
Here is a site that I often reference for tips and techniques, many are common and well-known others are not.
http://home.interlog.com/~khartlen/tips/tips.htm
I will also translate a few tips from older Tamiya publications that deal with Motor bikes and tips for improving them, again many of those are well known.
Of course people can/should also ask for tips/techniques on how to improve certain areas of their Kits.
Tip #1:
Improving Spark plug wires WITHOUT the need for drilling or cutting parts.
Materials needed:
1mm rubber tube(usually supplied in Kit)
0.5mm rubber/plastic covered wire(AM Spark plug wire)
Cut 3mm sections of the 1mm rubber tube (1 per spark plug), and cut the 0.5mm wire into the length given in the Instruction sheet.
Slide the 1mm tube over the sparkplug as per instruction, insert the 0.5mm wrie into the 1mm tube and secure. FINISHED.
I find this helps with the look of many custom choppers as they oftem use AM parts and wiring harnesses.
More to come later on.
