I have a P-51 on the bench, and as I was working through the sprue I had a thought…
For a boxed model set, not counting aftermarket add-on’s, what is the most complex model you ever built, from the point of view of number of parts on the trees?
I wonder if there is an entry in Guinness’ for this sort of thing?
I would guess the most complex model I ever built, including all the PE and aftermarket) was probably in the upper hundreds for parts (say 700). I do have the DML PzIV 3-in-1 on my shelf with a parts count around 1400.
None of my attempts would even come close, though. I think I’ve seen some articles in FSM with those crazyily detailed, scratchbuilt, superdetailed builds that have parts counts in the 10’s of thousands…
AHhh…mm, 2 most recent kits got to me… almost… an Italeri Panzer MK IV, it was my first armor kit in 25 yrs… I went a bit crazy and got PE, resin, metal barrel… etc… Indi tracks… It came out very well and even took a 1st at Downestcon, but It was wearing me thin in the end… first time indie tracks… to much overload with the roadwheels… and extras… shortly after that, I started Tamiya’s Pershing, same thing again… with a full engine bay/tranny bay… lots of PE… metal barrel… I alomst set this aside many times… but I managed and finished it…
In the end… it was worth it, but in the process, it was mind bending… [bnghead]
in the mean time… I completed 2 Bandia Starblazers battleships, small parts count… easy painting…
Mine was Academys 1/32 F-18D that i built for my bro(F-18D WSO). I ended up adding around 75 tiny bits of detail to the pit alone, 30 someodd bits to the nose gear, mains were in the 20s. The kit has 500 some odd parts, almost half of which are ordnance and option parts, I ended up somewhere in the 500-600 range.
Marder II w/ Soviet 76.2mm pac 36(r). Everything above the fenders was modified or scratch built. The gun features a open bore modeled around a 1/8 aluminum tube, turned on a drill & taper achieved with Tamiya putty. The indi- track links had 5 pour stubs each! @ aprox 94 links / side this alone consisted of dozens of hours of clean-up. The 1 piece molded gun cleaner was scratch built out of hypodermic needles & wood brackets. Most stowage equipment was scratch built as well, including a tripod for a MG-34.
The only one that comes to my mind are some kits I still have to build (not started) If they count, then they will be an old AMT/Eartl 1/25 scale ladder truck (with lots of scratch-built goodies) and a Monogram Ford F-250 (with a scratch-built bed and details to make it into a fire truck)
The most complex model I’ve accually got done and completed is the KV-1 model from Zenvino (I’m not sure of the spelling. It’s that manufacturer from Russia)
the most complex i know is the over engineered icm tb3 bomber with parisite fighters each of it’s 4 eng nacelles come complette with Full engines and you build the intire plane as the real one a compplete frame/skeliton the you lay the aitcraft’s skin over that
I got a model that is worth looking at. It’s not my model, but it is still interesting (and complex)
It’s a 1/40 scale model of the F/V Time Bandit (of Deadliest Catch fame) completely scratch-built and radio-controled. Martin Bak, the builder, completely scratch-built everything.
Hi, Well,not to brag, just state facts. 4,785 partsIn the hull and over 2,000 in the upperworks. The model? A seven foot model of the EDGEWATER PRINCESS.This was commissioned in 1979 ,finished in DECEMBER of 82. Each and every part was created from scratch.I just hope she still survives.That was the hardest thing I ever had to build ,much less part with.She was a model of one of the conjectural "luxury"sternwheel steamers on the MISSISSIPPI in 1864. The only other one I can think of is a 4 foot long 92’ COAST GUARD CUTTER built from the keelup for a client company to give as a retirement gift to their director of operations.I DID NOT count the parts on that one(I didn,t want to know! ) TANKERBUILDER P.S. I had to on the steamer to get paid at each stage of construction!!
For pure parts count, probably the Trumpeter Karl Morser with railway carriers, but honestly, it wasn’t very ‘complex’ in the sense that it was a beautifully engineered kit, and went together without a hitch.
Some kits that I have made, and that are still in the stash with every imaginable AM part that I could find for it, ugh, I dread to think the parts count, but I salivate at the joyous time of building it all.
I wonder if a distinction should be made between self-imposed complexity(addition of aftermarket resin and photoetch detail sets) and intrinsic complexity due to parts count and assembly sequence/breakdown?What say you?
I built Dragon’s “Easy Eight” sherman. T-80 tracks, 80 links per side, 2 parts each, and each link had a decent mold seam. Lots of scraping going on. it was fun, but if I’m going to do individual link tracks, They’d better be 1-piece. it was a fun kit, but very hard.
