Hey FSM, while some putty dries on my Hueys, I turned my attention to my Sabres.
There were a few decal options available on that auction site, and I let my wife pick which ones she liked most. As it turns out, she picked the same markings as the ones on Frank’s build.
I bought Aeromaster’s sheet, 48-790…
and I will be building FW-640.
This is a pre-Vietnam airframe, so (I understand) I can use the kit’s drop tanks.
I started by closing up the panels. They don’t fit very well. This is the ammo bay cover.
The gun cover on the lower fuselage half fits just as poorly. You can see above that cleaning up the seam led to some lost raised detail.
Speaking of losing detail, it seems as though cleaning up the fuselage joints will also lead to lost raised detail. Here you can see how the rear of the fuselages don’t line up well.
So, in an effort to make sure those seams as are good as I can get them, I removed the stabilizers (as you probably noticed above) to help with access.
One thing I noticed about the kit is that it includes two different afterburner sections, so the modeler can build an airframe from two different eras. Interestingly, those parts have engraved panel lines, although they are shallow and faint.
Now I have to decide if I want to rescribe the airframes, or if I want to try to replace the lost raised details with resin options, like Archer’s.
Oh! I also got the cockpits started. Here’s some preliminary work to prove that I’m not lying.
So, these are officially in the works. I’ll be going back and forth between these and the Hueys. I can see I have my work cut out for me…
Stay tuned!
-O
