Having a problem with moisture hoping someone could give me some ideas as to the problem.
I have an aircompressor with a moisture trap built into it, but I am still finding that after about 15-20 minutes of use, I start to get moisture shooting out of the nozzle - this is happening on both my Aztek 470 and Iwata HC-P.
THe moisture trap is actually part of the compressor and is at the end of it and you attach the hose to the top of it. I don’t know if this is the same for all compressors but I adjust the psi pressure by adjusting a screw at the bottom of the moisture trap.
I agree with what Mad Model Factory said. Get another water seperator.
Mounting a water seperator directly on the compressor is a bad idea as it picks up the constant moisture that the compressor produces from the heat of the motor and some gets past it. I would either get an inline moisture trap that installs in the airhose or buy another water seperator and mount it several feet away from the compressor and then connect the airbrush to it.
One other thing…Have you emptied the water out of the water seperator before trying the compressor and it still spits water?
I now this is common sense but sometimes we fail to do the little things that are so obvious. [;)]
