I am new to scale modeling and am using a second bedroom as my work space. It’s recently become increasingly challenging as I find myself wanting more room. I have a desk with a small fume hood that vents to the outside. My walls are pretty much taken up with shelving. Does anyone have space saving tips on how to do more with less?
Im a modeler on the go. Im working mainly out of hotel rooms these days since IM a contractor. Ive reduced my build kit to the essentials, and I got one of these building sets for gundams on Amazon for a few bucks, and it has almost everything I need. I added a few more things that over the years Ive found I need, but even when I worked at home, I had the end of the kitchen table with a cereal box taped to the tablecloth. Its not used for dinner much, and its directly under my hanging light for perfect illumination. I guess Ive got 11x14" space, and Ive worked with that for years. Paints and other stuff is mainly stored in 3 tier rolling storage cabinets. There are several versions of of this little kit. https://www.amazon.com/BXQINLENX-Professional-Modeler-Building-Repairing/dp/B01GHB745E/ref=redir_mobile_desktop?ie=UTF8&aaxitk=ENXL1Yz-qwewdKls2FF--Q&hsa_cr_id=8451739630401&ref_=sbx_be_s_sparkle_mcd_asin_1
To your specific issue, and working with limited space-I have a bench, and plenty of storage, but I also have a travel kit, to take on the road to shows, or meetups. I have a large toolbox, about 12" deep by 12" wide by 28" long. It has a nice lift-out storage tray, too In it, I have packed those things that are immediately necessary to do basic assembly and painting:
most of my jars and bottles of paints, along with thinners/solvents for them
liquid and tube styrene glue
CA glue
2-part epoxy glue
2-part epoxy putty
Paint brushes
Sculpting tools
an LED desk lamp
a cutting board
a wet palette
a ceramic palette
files, hobby knives & razor saws
pin vise and drill bits
With that kit, I can set up on a space of about 2 foot square and work.
So the tip there is to think about what you need to have immediately to hand, to do your work, and everything else can be stowed and retrieved as necessary.
I hope that helps, and I look forward to seeing your builds!
I have a 3 tray large fishing tackle box to keep my build tools in to take to work and club meetings. Works out fine. Combine that with a TV tray, setting the tool box on the floor, along with a cutting mat for the table, and should be good to go.
I’m like The Baron. I have to work on the dining table in our small apartment — about 950 square feet (88 square metres). I spread out a drop cloth, lay a self-healing cutting mat on it, and get out my tools and supplies, kept in large plastic boxes on a nearby closet shelf, set up two battery powered desk lamps. Set up and take down requires only two or three minutes, once paint brushes are cleaned. I took this photo perhaps two months after starting to build models again; today I use two lamps and a much larger cutting mat.
I probably could use an airbrush in our kitchen, but it would be fairly expensive and not very convenient. Instead, I built a spray booth out of a large cardboard box, installed a light bulb for heat on cold days, and use rattle cans. Works well, so far, although I do envy the control that airbrushing would allow.
While I have a nice work area, my primary hobby is not scale modeling. I can’t tie up my workbench constantly for models. This leads me to sharing that space as general work area, and a mostly dedicated electonics work area at the one side, with my computer setup on the far side of the area. I have a drawer I keep my air brush, sand paper, small files. I have a 3 drawer organizer (that is almost a 12" cube but not exactly) that my Testor small glass model paints, brushes, model glue tubes and tube putty are largely stored in. Then I have a cabinet above that is where I put my bottle model paints, and various other glues and things. Overall I don’t take alot of space up with my model specific stuff. I have a fume extractor box and the duct that I only bring to the workbench when I am using the airbrush. I don’t have room to keep it on my bench all the time. It doubles as a storage area for some parts I don’t need at this time that are painted so they don’t get scratched up. A primary thing is just have out what I need, and try to keep it to one model in progress. I put all the supplies and tools back when I stop for the evening/day usually.
Oh, you are so rare! My build team for “H.O.” and “N” at the Museum get so spread out the space alloted to me is non-existant. Now ,that said, I still can build pretty good in the same space this laptop takes up, and I do!
