I’m just wondering what the correct colours are, and if a conversion set or something is needed to bring them up to ADF specs.
Thanks in advance.
Will
Thanks in advance.
Will
Hi there,
Have a look at Hawkeyemodels.com.au (sorry can’t seem to get the link to work). They will have some relevant info for you.
Rich
Thanks Rich
Will
This is a suggestion from David Edwards who posted over at the Aussie Modeller International site a while ago:
"I’ve not been able to find an out of the tin match, but the Modelmaster US WW2 interior green looks close. Ditto Humbrol 150 which is I think Forest Green.
Another idea, maybe 50/50 FS 34102/34087
As for the Iroquois, when the Army inherted them from the RAAF the green in the camouflage pattern was indeed 34102, and to my Mk1 eyeball they still look the same - see them at Avalon each airshow and there was one flying a racetrack pattern over my place during the Commonwealth Games silliness."
Here are some photos of the same Blackhawk in East Timor
From what I can tell, the only additions needed to a standard UH-60L is the step bar below the troop doors, square folding tail plane, towel rack antenna, and a few other different antenni.
Hawkeye Models does a couple great sets of Aussie UH-60 decals too. They are listed by its civilian model name, S-70-B9. The Academy 1/35 MH-60G would be a good starting point. It already comes with the towel bar antenna and folding tail plane in the kit.
The colors look like Testors Model Master Forest Green, Dark Tan, and Flat Black to me.
I’ll try and dig out the FS numbers when i have the chance. Also we use the MAG 58 (M240) as door guns.
That lighter colour looks like Desert Pink (RAF Gulf War colours) which is Humbrol 250
Rich
Thanks, FS#s would be great. The US uses the M240 as doorguns too, Academy’s kits are a little dated in that area.
Thanks everyone who responded.
Will
Rich, the sand colur is FS 30219
Thanks, my Mrs. always says I’m colour blind, she’s probably right…( for once…!!)
Will,
The colors are FS30219, FS34082, and FS37038. The S-70A-9 is similar to late UH-60A’s with the most notable external differences being the cabin steps, towel rack antenna, and three-piece stab as noted earlier. The ADF also utilizes an alternate cabin seating arrangement where the six centrally located troop seats are replace by six (3 per side) that run down the center of the cabin.
HTH,
Thankyou Mike!!
Will
If availability is easier, 34102 is a pretty close match. Most of us on the AMI forum here in Australia have concluded that will do, as 34082 is not always readily available.
Its kinda sad what happened the other day. Losing a pilot and an SAS member… A Blackhawk is also on my to do list…
Chris
mmm, The blackhawks and SAS don’t have a good record together, a little while back they lost eighteen men in a single crash.
Will
G’day,
Just found this thread, as I’m looking at doing an Australian Army Blackhawk.
Can anyone recommend a good base model to start with. I’ve read some good reviews about the Italeri kits, and was looking at the “UH-60/MH-60 BLACK HAWK Night Raid” Kit.
I like to model in 1/48 as space is prohibitive, and I have started an aircraft collection in 1/48.
Would this kit be a good start for an Australian Army Blackhawk?
Thanks in advance
Andrew
