MM Enamel Primer from a Bottle Drying Time?
Got me some MM gray primer drying on my figure. Does anyone know how long it takes to completely dry? Thank you, Dave
Depends very much on weather. But it can, under some conditions, take several days or a week. While I like using enamel, the long times bothered me so I put together a paint dryer. Now, under worst conditions paint usually dries in less than a day.
Don, thanks very much for the reply. I guess my second question would be, can I paint on primer that isn’t fully cured? I had the dehumidifier going for quite a few hours but the weather is humid, and this is indeed a basement.
Dave
Definitely do not paint on uncured primer with a brush. I wouldn’t advise it either with an airbrush but the consequences are not as drastic. Most primers dry pretty fast- what primer are you using? Consider using a fast dry primer in future.
Don, using Testors MM enamel gray primer from a bottle, not a rattle can. Guess I’ll give it a little longer with the dehumidifier running. Thank you again!
Dave
I have all but given up on enamel anything for this reason. Takes too flippin’ long to dry. I use lacquer-based primers in a rattle can. Sprayed, they are usually good to go in a couple hours. I reckon if you brush them it’d be a little longer, but still better than waiting days or a week for an enamel.
Ahhh, so maybe I’ll use lacquer from a can. Thank you sir, thank you very much!
Not a problem at all.
Here are my ‘go-to’ primers. I mostly use the white because a color coat over it is more ‘true’. The gray primer tends to darken a top coat just a bit. I’m sure other brands make a lacquer-based primer as well:
TY, I’m coming back from my 4th hiatus from the hobby. Didn’t even know lacquer based primers existed. Looking forward to discovering new toys as I re-enter the hobby.
I use lacquer primers too, but stick with the enamel paint. I don’t like acrylic lacquers, but find the available colors in normal lacquer lacking, except for model cars.
I still have the old Kalmbach “How to build plastic ship models”. He recommends lacquers for hull painting. I don’t know what it is about the way lacquers settle or cover, but they look better for certain applications.
Dave
