MK 108 30mm auto cannon question
Finalizing the Eduard FW190 A8R2 – the outboard MK108s from Master Model come with optional ‘Blast Tubes’ that I have not seen in any reference material - from some pictures they seem to be standard – any further info is appreciated
Dog
Would you happen to have a photo of what you are referring to on your kit? That might be helpful for folks not familair with the Eduard kit, but who know the FW-190.
https://hobbyworld-usa.com/index.php?id_product=5117&rewrite=master-german-aircraft-machine-gun-mk-108-30mm-barrels-blast-tubes-2pcs-009&controller=product&id_lang=1
these MK 108 (30mm) replaced the outboard MG151 20mm cannon – photos seem to indicate the ‘blast tube’ was widely used - just want to see if anyone has more info about them-
Thanks
Looks like they were used… just cant say how commonly
Thanks Stik - yes , Im using that photo as my main reference-- had to do a bit of surgery to get the barrels into the wing mounts – appreciate your help
Dog
The Mk108 was a compact gun with a short barrel, so replacing a MG151 would place it far enough behind the wing leading edge to require the use of a blast tube. That’s my theory.
thanks the FW went up on the shelf a few weeks ago
